+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 42
Thread: Help: Regulated Power Supply
  1. #16
    hardcore misery Newbie
    Join Date
    Oct 2006
    Posts
    168
    so the 60V Dc output can be produced by the transformer? depends on the turns ratio? probably a step down transformer... is it correct?
  2. #17
    Join Date
    Oct 2006
    Posts
    168
    can anyone check this for errors? dc output = 15v
    load current = 1A
    input voltage = 220/60hz
  3. #18
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    If the transformer is 12VAC at 15VA then it will work. But the output isn't regulated, the voltage will change if the mains voltage changes and it will change when the load current changes. The output will also have about 1V of 120Hz ripple. This circuit could feed a 7809 voltage regulator IC to give a regulated 9VDC output.
  4. #19
    Join Date
    Oct 2006
    Posts
    168
    we were not required to use an IC to our project...
    so is ti possible to step down a 220VAC into 15VDC? then by using a voltage multiplier, 15VDC can be 60VDC? that is my design... and it should be regulated...
  5. #20
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,783
    Quote Originally Posted by hardcore misery
    In theory, but it's not generally a practical solution - forget about voltage multipliers, they are a waste of time!.
  6. #21
    Join Date
    Oct 2006
    Posts
    168
    sir...can you suggest an alternative to voltage multiplier? how can i produce a 60V DC output from a 220VAC with a load current of 1A and by using discrete components? hoping for help here... sorry for my bad english... godbless to all
  7. #22
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,783
    You use the correct voltage transformer, then (if it needs to be regulated) you add a discrete component regulator on the output - the transformer will need to be a different voltage for regulated or not!.
    For the 15V rail either use a seperate winding or a seperate transformer, it's really too big a drop for a linear regulator.
  8. #23
    Join Date
    Oct 2006
    Posts
    168
    sir, what do you mean by correct voltage transformer? so it is impossible to step down a 220VAC into a 60VDC or 15DC? the DC output should be regulated...
  9. #24
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,783
    A mains transformer outputs AC, for an unregulated DC you would require a transformer a little over 40V AC to give roughly 60V DC after rectification and smoothing. For a regulated supply you need more than 60V to feed the regulator - so you would need a higher voltage transformer. The actual voltage depends on the design of the regulator, and on the specifications it needs to meet.
  10. #25
    Join Date
    Oct 2006
    Posts
    168
    so i can't use a 220VAC input? but that is the required input voltage for our designed PSU...i have no option but to choose 60V (or 15V but to multiply it or 12V but to make it 42V to be unique with my other classmates) as an output DC voltage...
  11. #26
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,783
    Yes, of course you can (and should), 220V is the PRIMARY of the transformer, it's the secondary that gives the output voltage.
    If your knowledge is so limited I suggest you go and talk to your teacher, either you haven't been paying attention in class, or you've been ill and missed all the lessons!.
  12. #27
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,048
    I've already shown you where to see a schematic for a discrete voltage.
    But here's the Googles I've used to get the results.
    http://www.google.com/search?num=100...ic&btnG=Search
    http://www.google.com/search?client=...utf-8&oe=utf-8
    if I know the answer.
  13. #28
    Join Date
    Oct 2006
    Posts
    168
    please ignore the captions on the image...
    sir.. is the 220VAC a rms? or a peak to peak voltage?
    all i did was to assume that as a rms voltage and step down it to 60Vrms
    which i converted the 60Vrms to Vpeak( 60V * 1.414 ) then
    this voltage runs though 2 diodes ( Vpeak - 0.7 - 0.7 )
    then the resulting voltage is the Vsupply which is rectified...
    after that.. i'm going to solve for R1 which is (Vsupply - Vz all over Iload + Iz)
    zener diode is based on the expected DC output..so i've chosen 56V/1W zener voltage...
    how can i assume a Iz and a Vz? our load current is from 750mA - 1A
    so if i computed for R1... and the Vdrop across R1 ( vsupply - Vz)
    am i going to use voltage divider rule for the expected DC output?
    (Vout = (R1/ (R1 + RL))*Vdrop)?
    i have the complete details... i'm asking for your confirmation against my ideas given on this design...
    godbless to all of you...
    anyway, i'm sorry for my bad english...
  14. #29
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    Your 1k resistor has 27.5mA in it without a load. So if the load draws 27.5mA then the zener diode doesn't regulate and if the load draws more than 27.5mA then the output voltage drops.
    A zener diode is a lousy voltage regulator because it wastes power when the supply doen't have a load.
    Change the 1k resistor to 27 ohms. Then the current in it and in the zener diode is 1.02A without a load. The power in the 56V zener diode is a whopping 27.9W! But you can load it with 1A and it will still have 56V regulated.
    A zener diode is a shunt regulator. Use a transistor as a series regulator (instead of the 1k resistor) then it won't waste much power when there isn't a load. A zener diode can be from its base to ground and the transistor is an emitter-follower. The zener diode and the base of the transistor will need a small amount of current from the 83V unregulated to function that is supplied by a suitable resistor.
  15. #30
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,048
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. 24v DC Power Supply (Help & Information Wanted Urgently)
    By ampthetex in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th November 2006, 12:45 PM
  2. Dual voltage regulated power supply
    By eng1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th May 2006, 03:08 PM
  3. 12V 0.5A regulated Power supply no IC regulators
    By fingers in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st May 2006, 04:28 PM
  4. Using old power modem power supply
    By mongoq in forum General Electronics Chat
    Latest: 24th February 2005, 08:05 PM
  5. Nice regulated power supply for beginners, only $19.95
    By TheOne in forum General Electronics Chat
    Latest: 28th January 2005, 10:08 PM
Tags for this Thread
