Old 1st October 2006, 02:15 AM   (permalink)
mettam is on a distinguished road
Default How can I check a transistor is working
I need to check if my Mosfet Transistors are working.
I have read that checking FET (field effect Transistors) with a multimeter can permanently damage the transistor.
Has anyone been able to check Mosfet Transistors using a multimeter ?
I am a newbie so if someone could walk me through the process I would apreciate it.
This is the kind of MultiMeter I have, its called a DVM810 and it does have transistor-checking feature. (link to my multi meter bellow)
http://www.oselectronics.com/Images/pg_5/dvm810.gif
(link to a picture of a Mosfet Transistor)
http://www.robot-italy.com/images/images_med/306002.jpg
awaiting your reply's thank you.
J.
mettam is offline   Reply With Quote
Old 1st October 2006, 03:37 AM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
The max voltage rating for most Mosfets is 20V from gate to source. When on "diode test" your meter supplies only 3V or less. On "ohms" it supplies about 0.2V.
Static electricity might danage a Mosfet when you connect your meter.
Your meter doesn't supply enough gate voltage to a Mosfet to turn it on for a test. You will need to make a separate Mosfet tester with a 9V battery or something.
Old 1st October 2006, 03:48 AM   (permalink)
Experienced Member
philba is just really nicephilba is just really nicephilba is just really nice
I believe the transisotr checkers on the cheap DMMs are for BJTs, not fets.
philba is offline   Reply With Quote
Old 1st October 2006, 05:02 PM   (permalink)
Experienced Member
kchriste is a name known to allkchriste is a name known to allkchriste is a name known to allkchriste is a name known to allkchriste is a name known to allkchriste is a name known to all
You can do it with the simple "diode check" function built into most digital meters that are powered by 9V batteries:
Short the gate to the source.
Your diode check from drain to source will show an open in one direction and a "diode" in the other.
Connect the meters minus lead to the source.
Unshort the gate and connect the meters positive lead to the gate. It should read open.
Then without touching the gate with anything else, move the meters positive lead to the drain. You shound see a short which will dissappear if you short the gate to the source again.
This may not work with all meters or MOSFETs but it is a quick and easy "go/no-go test.
kchriste is offline   Reply With Quote
Old 1st October 2006, 09:56 PM   (permalink)
Experienced Member
user1453 is on a distinguished road
Send a message via MSN to user1453
look at
http://www.techlib.com/electronics/spotchecker.htm
user1453 is offline   Reply With Quote
Old 2nd October 2006, 01:47 AM   (permalink)
Experienced Member
atferrari is on a distinguished road
The text in the first is an exact quote (copy?) from the second.
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
atferrari is offline   Reply With Quote
faulty digital components testing,checking walters General Electronics Chat 5 22nd August 2005 07:10 PM
Telephone Remote control Circuit not working MEHLULI Electronic Projects Design/Ideas/Reviews 2 13th April 2005 07:37 AM
Chip talk dreamproject Electronic Projects Design/Ideas/Reviews 8 2nd April 2005 07:24 PM
Motor control interface dreamproject Micro Controllers 0 31st March 2005 03:48 AM
PLS HELP!!!! Need working program asap..thank you!! silverferro Micro Controllers 7 22nd July 2004 08:46 AM
