Hi, How do I tell the power of a carbon resistor from its size ? Is there any reference on the web I can consult ? Thanks | |
A Carbon film resistor can be identified by it's markings, there should be between 3-5 colored bands which are used to identify a resistor. Also size doesn't always matter when it comes to electronics, although with carbon film resistors it does, the longer the piece of carbon film, the more resistance, though it usually doesn't take much. Here's the link. http://webhome.idirect.com/~jadams/e...esist_calc.htm Note: Look VERY CAREFULLY at the resistor, some colors are difficult to distinguish like blue/green, and violet/blue, I know the last one sounds kind of funky, but one time it took me about 1/2 an hour to decide which one it was, I looked under many different lights, but didn't actually decide until I went out into sunlight (The best to identify colors under, other lights emit a slightly different color, like a yellowish/pale color which can impare your ability to identify some colors) and some of these bands can be under 1mm in size so a magnifying glass may help.
__________________ E=MC^18357891237358179238, it\'ll still come out right every time. Try it some time, it\'s all relative to the equation. Take that Einstein.
| | #3 | |
Any ideas on this ? | ||
| | #5 | |
__________________ subzero | ||
| | #6 |
my lazy butt skips the bands and goes straight for the DMM. As for determining power, I dont know
__________________ A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who. A recent study shows that research causes cancer in rats. -- I dunno who said that one either. | |
| | #7 |
haha i agree with skipping the bands... who is going to be playing with carbon resistors w/o a DMM nearby anyway?
__________________ thanks, david | |
| | #8 |
i don't see any way to determine the power of the reistor exept from it's size..... maybe the colour of the reistor means something.....? | |
| | #9 | |
E.g.: Lenght: 10mm, Diameter: 1mm ----> 1/4W Lenght: 20mm, Diameter: 3mm ----> 1W etc.... | ||
| | #10 |
look at the links i posted......the first one.....it has a chart that contains the dimensions of different power resistors. i think that the dimensions don't matter from different manufacturers | |
| | #11 | |
| | #12 |
i don't know about standards....,but the fact is that you will not find a 2 W resistor from one manufacturer the same size as a 1/2W resistor from another manufacturer....if you know what i mean/////
| | #13 | |
| | #14 | |
As for the power of carbon resistors I would bet there is no set standard. Obviously size plays a factor, so good luck sbeyeta!!
| | #15 |
yes, it can do that, but you CAN NOT mesure the power of a resistor with a DMM the best way is from it's size, and probably the only way | |
