Old 28th September 2006, 09:39 AM   (permalink)
Default coils in a fm receiver
hi there
i would like to know how to or what the exact properties are of a wire in the radio receiver in order to have an inductance value of 78nH and 70nH.
I mean what type of wire, the dimensions , how many turns etc would i need to get an inductance from a coil of the above values......help please!
thanks in advance
preeste is offline
Old 28th September 2006, 10:06 AM   (permalink)
There's no real answer to that - because of the high frequency and low inductance, there are far too many other factors affecting it to wind the coil from theoretical calculations.
Old 28th September 2006, 10:43 AM   (permalink)
There are formulae around for calculating the inductance of and air coil and it's true that at higher frequencies they aren't that acurate. These can be found from Google but here is the page I find the most useful.
http://www.ee.surrey.ac.uk/Workshop/...air_coils.html
Screen name: Aloone_Jonez
Hero999 is offline
Old 28th September 2006, 12:36 PM   (permalink)
The website that Hero999 mentions appears to be excellent. An alternative - if you can get a copy of the Radio Amateurs Handbook published by the American Radio Relay League you will find some theoretical and practical information as well.
stevez
stevez is offline
Old 28th September 2006, 12:45 PM   (permalink)
Or six turns of thick copper wire around a pencil?.
Old 28th September 2006, 01:17 PM   (permalink)
The usual way to solve your problem requires an instrument that may be a bit out of your price range. It is called a network analyzer. It will measure the s-parameters of a network as a function of frequency. If you need this for a short time only you might be able to rent one.
Papabravo is offline
Old 28th September 2006, 01:38 PM   (permalink)
Dont forget the old fashioned instrument, the Q -Meter.
Just as effective at measuring inductance and capacitance, and somewhat cheaper than a network analyser!
JimB is offline
Old 28th September 2006, 02:01 PM   (permalink)
Whatever capacitor you tune the coil with will also have an unknown value due to stray capacitance in parallel with it.
That is why radios have trimmer capacitors and trimmer inductors to adjust as part of their alignment.
audioguru is offline
Old 28th September 2006, 07:41 PM   (permalink)
A dip meter is another way to measure the approximate inductance - maybe that's what JimB is calling a Q-meter though I am not sure.
The inductor is combined with a known value capacitor - the dip meter coil is placed near the inductor. The dip meter is an oscillator with a current meter - and when the frequency of the dip meter oscillator matches the resonant frequency of the ind/cap pair it dips. By knowing the frequency and capacitance one can calculate the inductance.
stevez
stevez is offline
Old 28th September 2006, 08:50 PM   (permalink)
No, a dip meter or GDO is a GDO and a Q-meter is a Q-meter!
A Q-meter is a combination of an oscillator, a voltmeter and a set of calibrated variable capacitors. Usually there is a set of calibrated plug-in inductors, or you use your own inductor ie the device under test.
It is set up so that the capacitors and coil are connected in parallel.
There is usually a low value (1 ohm) resistor in series with the capacitors, the oscillator is used to inject the excitation current into the LC circuit across this low value resistor.
The voltmeter measures the voltage across the capacitor.
From memory, the Q of the circuit is then the ratio of the voltage across the capacitor to the voltage across the 1 ohm resistor.
All sounds a bit weird if you have not seen one before.
Have a look at the circuit attached here which I have cut from an old textbook.
JimB is offline
Old 28th September 2006, 09:00 PM   (permalink)
JimB - thanks! I recall reading a procedure for estimating the Q of a tuned circuit with a GDO. One would tune to resonance then some point either side to establish some half-power or other benchmark. I can't comment on the validity of the procedure.
A little extra for preeste - once you've got the coil you'll soon discover that if it is part of an oscillator that it will be extremely sensitive to nearby objects as well as vibration or deformation. Quite often some dope or other glue like substance is applied to provide some firm support for the turns.
stevez
stevez is offline
Old 28th September 2006, 10:31 PM   (permalink)
There are many way of measuring the Q, you could also connect the capacitor in parallel with the inductor and a current sense resistor in series with them both; if you know the voltage across the voltage across the resistor and inductor then you can work out the Q.
Hero999 is offline
Old 29th September 2006, 01:34 AM   (permalink)
The Q-meter and the Grid Dip Oscillator are interesting in a historical context. There use was primarily for the HF bands in the 3-30 MHz. range. Would they continue to work at VHF? Do you suppose either one would be helpful to the original poster in his quest to get design and build coils for his FM Receiver?
Old 29th September 2006, 02:29 AM   (permalink)
I have made filters in the several hundred megacycle range by winding the coil from formula then resonating it with a known capacitor and compressing or streaching the coil for a fine tune. The size of the wire is not important in a receiver, but I like to make it stiff enuf that it is self supporting. I surface mount the coil by bending the start and finish of the coil at 90 degrees so it doesn't roll over. The equation is from the "Engineer's Handbook" : L=n^2(r^2/(9*r+10*l)) where L=inductance in microhenries, n=number of turns, r=radius of coil to the center of the wire, l=the length of the winding. This is very accurate if you remember that the length of the leads is part of the inductance not included in the formula.
Russlk is offline
Old 29th September 2006, 08:27 AM   (permalink)
In the context of the original question, about as useful as a network analyser I would say.
JimB is offline
Building a DCF77 receiver eblc1388 General Electronics Chat 3 19th April 2006 09:25 AM
RCM3400 interfacing with M12+ Oncore GPS receiver joneo Micro Controllers 3 3rd November 2004 07:41 PM
Amplifier for AM receiver ua741 Electronic Projects Design/Ideas/Reviews 2 27th July 2004 02:11 PM
Amplifier for AM receiver ua741 Electronic Projects Design/Ideas/Reviews 0 27th July 2004 05:35 AM
I NEED HELP! HOW DO I MOD. A UHF 2 CHANNEL RECEIVER ...... JC Electronic Projects Design/Ideas/Reviews 1 1st March 2003 11:48 AM
