I have 3 Solar Cells connected in series the + is attached to a diode and the diode is connected to the + of the Nicd battery, the - of the solar cell is connected to the - of the battery (see attached photo to see what I did.)
Can someone tell me if I have attached the battery the correct way to the solar cells for charging. Justin. |
Experienced Member
Your wiring is correct and the battery should charge if the solar panels can supply a total of 6.3V at 60mA.
Uncle $crooge |
Would you know what my NiCd should read once fully charged ? If I look at 4 AA batteries they are about 6V and 1.500A. I'm not sure about how to read the Amps on my multimeter, I think it is telling me 1.5A. Could this be correct ? Should these 4 AA NiCd batteries once fully charged read roughly the same Amp as 4 AA Duracell ? |
(permalink) | ||||
Experienced Member
Uncle $crooge |
Experienced Member
The voltage tells you little about the state-of-charge. State of charge is not a simple thing to determine on NiMH. In fact, the voltage initially increases while charging, though only slightly, and near the time where it reaches full charge it actually decreases for a brief time.
It gets rougher with solar cells because the current is not consistent. You may get 200ma at first, but later in the day you have only 50mA. With the drop in current, the battery voltage will go down. Likewise, a fully charged cell that was at 1.25v under a cloud may be suddenly exposed to 200mA as the sun comes back. It may take awhile for the battery voltage to rise again. You may have problems with overcharging, because those look like fairly small batteries. 200mA could be enough to dry them out if left on too long after fully charged. But then again this probably isn't going to be a setup used for a really long time.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
Experienced Member
I would add: The charged voltage , unloaded battery is a useless indication of the capability of the battery. A good test would be to load the a recharged battery with 10% of maximum capacity for 20 seconds while monitoring the battery voltage. A fully charged NiCd battery is not in good condition if its voltage drops by 10%. hawk2eye
hawk2eye |
Experienced Member
Can this solar panel charge NiMH batteries? Can they be charged and used simultaneously? Thanks
Superman Returns.. http://www.supermanhomepage.com/imag...an-returns.gif My friend created this account for me.. LOL http://bananasiong.myminicity.com oh.. somemore http://bananasiong.myminicity.com/env |
Experienced Member
The solar cells meet their spec for only 1 hour per day when it is sunny at noon. It will take many days to partially charge the battery when it doesn't have a load. The battery will go dead if there is a load, because the voltage and current from the solar cells aren't enough.
Uncle $crooge |
Experienced Member
(permalink) | ||
Experienced Member
Uncle $crooge |
Experienced Member
I'll use it to run a DC motor.
Three things are connected in parallel: Solar panel, rechargeable batteries (Ni-MH) and load (DC motor). I'll start with the fully charged batteries, the DC motor is powered by the batteries, then the solar panel keeps on charging to the batteries. Is this possible? I've never tried them out, I'm still planning.
Experienced Member
Do the math.
Is the average solar cell current more than the motor's current? I doubt it.
Uncle $crooge |
Experienced Member
Of course no, but why do we need to concern this??? The motor is not running all the time, then the batteries will be charged when it is not running.
Experienced Member
The solar cells are in bright direct sunlight only at noon on a sunny day. They will charge the battery for only 1 hour each day! You could make a moving platform point the solar cells at the sun as it moves, then maybe the battery will charge 3 hours each day.
You don't say how much current the motor uses, you don't say how long you want it to run each day.
Uncle $crooge |
Experienced Member
| Charging a 12v battery with Solar panel.. | barrymons | Electronic Projects Design/Ideas/Reviews | 11 | 21st April 2006 12:44 AM |
| NiCd charging for dummies? | uniqorn | General Electronics Chat | 2 | 29th March 2006 02:55 PM |
| Charging System of Solar Car | devonsc | General Electronics Chat | 3 | 21st December 2004 04:42 AM |
| Solar tracking System for solar cells | bogdanfirst | Electronic Projects Design/Ideas/Reviews | 10 | 3rd March 2004 06:55 PM |
| A few questions regarding capacitors and solar cells... | thebigbasicq | Electronic Projects Design/Ideas/Reviews | 10 | 26th April 2003 02:53 PM |
