Negative feedback in this circuit is provided by R2, correct? The output is phase inverted, so feeding it into the base through R2 subtracts from the input signal to some degree. What's the point of doing this? It would seem to attenuate the amplification, but why? This prevents distortion during signals that peak the transistor? DC gain is the Hfe value, correct? So the transistors are widely variable in construction, so one may give much more gain than another out of the same box. That much I understand. What is DC operating point, then? I'm guessing this has something to do with the range of currents that the transistor behaves in a linear fashion? Assuming I know the measured Hfe of a particular transistor, could I calculate the expected voltage gain for a given signal? I want to stop here for a second and say thank you to everyone who has taken the time to post here. This thread has already taught me quite a bit that I didn't previously understand. I'd also like to acknowledge that I understand the Op amp solution is obviously better, and I'll definitely build that as well. At this point, I'm simply playing with this circuit as a means to learn more and understand it may not give me a very usuable product. I did fix my wiring mistake, and I still don't get enough gain. Cranking up the soundcard's software gain control adds a lot of static that may well be from my circuit. Another thing I noticed is that I get some AM reception when I touch the mic casing. Sounded like talk radio. I'd imagine that's a grounding problem easy enough to chase down. TJ
__________________ KF4GAU I haven't burned myself with the soldering iron in at least.. Ow that's hot! Last edited by systemloc; 22nd September 2006 at 08:58 PM. | ||
| | (permalink) | |||||
The opposite occurs if the transistor's DC gain is too high. The signal in R2 cancels some of the input signal which reduces the circuit's AC gain and also cancels some of the non-linear distortion. Quote:
__________________ Uncle $crooge Last edited by audioguru; 22nd September 2006 at 10:04 PM. | ||||||
In order to get best S/N performance from a signal source operating at its the lowest level, impedance matching is the ONLY way to go. I agree with your comments ....for a "majority of connections" which can be defined for high S/N levels, then maximum voltage transfer gives an advantage over impedance matching. BUT: Using your technique, a mike pickup would produce poorer S/N for low level signals. hawk2eye
__________________ hawk2eye | ||
And it's not 'my' technique, it's EVERYONE'S technique - can you name a single audio input where impedance matching is used?. If you're thinking of suggesting microphone transformers?, they are simply used to change the impedance, which is then fed into a much higher impedance as normal. | ||
Nigel Goodwin Apparently you have not been involved with low level, noisy signals very much. I am correct and EVERYONE's technique is wrong. I have emphasized the words "impedance matching" with ...vvv... marks. see: http://www.cinemag.biz/mic_input/mic_input.html .................|||||||||||||||||||||| .................vvvvvvvvvvvvvvvvvv............... .. < Excellent impedance matching between the microphone and the pre-amplifier, < excellent balance and common mode rejection ratios (CMRR), very low distortion, < and superior bandwidth see: http://www.cinemag.biz/mic_input/mic_input.html hawk2eye
| | (permalink) | ||
As I said previously, this ONLY matches the microphone to the transformer, and NOT the transformer to the preamp, not even back in the 1940's where that technology comes from!. Presumably the advantages you're talking about are from using a BALANCED microphone output? - where any common mode 'noise' on the long cable is cancelled out in the transformer?. It's only an advantage for long cables in poor environments, and 'modern' (last 20-30 years?) electroniclly balanced inputs far out perform transformers. Transformers have too many drawbacks, and are far too expensive to be in common use - modern electronics have rendered them fairly obselete. Almost any modern PA gear has electronically balanced inputs, and this helps to reduce any noise pickup on the cabling. | |||
| [quote=Nigel Goodwin]Why would you have noisey signals?. As I said previously, this ONLY matches the microphone to the transformer, and NOT the transformer to the preamp, not even back in the 1940's where that technology comes from!. ++++++++++++++++++++++++++++++++++ Nigel: I repeat: the mike impedance to the amplifier is (Npri/Nsec)^2*Rgen as shown by ANY text book that describes impedance matching. Look it up. there is nothing wrong in being wrong. .................................................. .......................... The input transformer serves as an impedance matching device. mathematically, for the transformer Nout*Iout = Nin*Iin Eout/Ein = Nout/Nin then Eout = (Nout/Nin)Ein Iout = (Nin/Nout)Iin Rout = Eout/Iout Rout =(Nout/Nin)^2 *Ein/Iin Rout =(Nout/Nin)^2 *Rin hawk2eye
| I worked with very high quality PA amplifiers. They used an input transformer for dynamic microphones as a balanced connection for them. The transformers were used at impedances far higher than the mics and as stepup transformers to reduce the noise of the following opamp since then it didn't need such a high gain.
| | (permalink) | ||
| [quote=hawk2eye] Quote:
| Hi Nigel, I worked with TOA brand, a Japanese sound systems company, until 6 years ago. The expensive amplifiers have a high quality input transformer for perfect balancing and for a voltage stepup which feed a very low noise opamp. Although they were small, the transformers have a good low frequency response because they are used with their impedance unmatched. Their cheaper amplifiers use transistors as an almost balanced input.
I suspect their only reason to use a mike transformer is so they can charge a higher price?, and it's certainly pretty pricey, but all that vocal PA gear is - I've never been able to understand why?, it's certainly NOT because of design or build quality - perhaps just small sales figures?, or because they are selling to industrial users?. BTW, just checked the mike preamp spec on a cheap Behringer mixer: Input impedance 2.6K balanced. (for 50, 150, and 600 ohm mikes) Frequency response 10Hz to 200KHz -3dB. (why bother to 200KHz?) Signal to noise ratio 110dB Mic E.I.N. (20Hz to 20KHz) @ 0 ohms, 134dB @ 50 ohms, 131dB @ 150 ohms, 129dB Pretty impressive specs, although a GOOD transformer will beat it on CMR, which interestingly they don't quote!. EDIT: BTW Audioguru, you mention the voltage step-up of the transformer, have you ever actually measured how much that is?, or the actual impedances of the transformer?, if not I suspect you will be quite suprised if you do!. Last edited by Nigel Goodwin; 23rd September 2006 at 02:44 PM. | ||
| The cheap TOA mixer has recently been discontinued. Its mic input S/N spec is 126dB @200 ohms. I don't know the ratio of the input transformer. Their products were pretty reliable. Very few items were returned during the 2 years to 5 years warranty. Their best power amps had a "no questions asked" 5 years warranty and none came back for repairs. They had 1500 dealers in Canada.
None of it has ever impressed me, but the usage doesn't really impress me either, and it doesn't require any great specifications for it's intended use. I've always been VERY interested in high power audio PA, for band and disco use - and much of that is very well designed and constructed, but it has a MUCH harder life than vocal announcement type PA. | ||
| Hi Nigel, TOA designs are conservative tried and proven ones, nothing new. The high end amplifiers and speakers are used in live show theaters and sound excellent. I heard some background music systems in stores that sound excellent.
| Interference on sound card | grrr_arrghh | General Electronics Chat | 17 | 27th May 2004 07:54 PM |
| Protect sound card when using PC-based oscilloscopes | grrr_arrghh | General Electronics Chat | 11 | 25th May 2004 01:32 PM |
| Sound card -> TV | 0mega | General Electronics Chat | 2 | 2nd April 2004 07:06 AM |
| Thermal monitoring using sound card | kieran | Electronic Projects Design/Ideas/Reviews | 1 | 2nd March 2004 06:05 AM |
| Sound card used as power supply | smitchell82 | General Electronics Chat | 1 | 4th September 2003 11:19 PM |
