I have been looking at the common collector configuration of an NPN transistor and can't fiugre out why it works the way it does. I've not found anything online that helps me understand this. Horowitz/Hill only has a brief section on it.
By the way, the CC config looks like a nice way to reduce input voltage with out dividing it and thus increasing impedence. Of couse, you have to deal with Vbesat drop. So, my main question is why is the output voltage at the emitter limited to the base voltage (minus Vbesat). What is the mechanism? Maybe a better way to ask it is why is the voltage gain approximately 1 (actually (Vb - Vbesat)/Vb )? |
The simple answer is that Vbe must be greater than about 0.7 volts for the transistor to be on. The collector is clamped to the supply voltage. As the transistor turns on and current begins to flow that current raises the potential of the emitter which reduces Vbe and trys to turn it off. To keep the transistor on Vb has to rise.
No matter what you do with the supply on the base, the output will never be greater than the 5V on the collector. With the base supply at 15V, the base resistor will drop 9.5 volts, Vb will be about 5.5V, and the output will be about 4.8V assuming Vce to be about 0.2V. Note that Vbe is pegged at about 0.7V Last edited by Papabravo; 21st September 2006 at 07:17 PM. |
This approximation omits the resistance of the source, and the intrinsic base resistance (which, if it were included, would be divided by (beta+1) and then added into the denominator term), as well as some other generally insignificant terms. |
look in Horowitz/ Hill p70, fig 2.16 that explains the AC coupled emitter follower,(or CC) the design is also shown. Your drawing is true for a simulation, but neglects the bias circuit. A capacitor is often used to couple the signal into a circuit to avoid disturbing DC input bias voltage. A second capacitor is often used to couple the circuit output to a load : to avoid DC loading . hawk2eye
hawk2eye |
| Looking for RGB LED PLCC4 (Common Cathode) | 2camjohn | Datasheet/Parts Requests | 6 | 12th May 2006 07:55 PM |
| Electric Heater and FeCl3 Questions: Lots of em | DigiTan | General Electronics Chat | 13 | 3rd January 2006 07:45 AM |
| 16F84 PIC stupid questions! | epilot | Micro Controllers | 44 | 29th September 2005 08:38 PM |
| More dumb questions | 2camjohn | Micro Controllers | 8 | 29th March 2004 04:19 PM |
| Electronics Pre-Test questions | Mike_07 | General Electronics Chat | 0 | 13th November 2003 02:21 AM |
