Old 19th September 2006, 03:39 AM   (permalink)
Default 3.3v bridge amp chip
I need to run a 32 ohm headphone off of 3.3v, but an output voltage of around 3V peak-to-peak has proven to be somewhat inadequate for my needs.
I would like to have a cheap dual-output IC that runs nearly rail-to-rail outputs and is capable of bridge mode. With bridge mode I can get closer to 6V peak-to-peak which has proven to be quite adequate.
It's for an in-headset amplifier, where I have 2 separate wires from each speaker accessible. In fact, I actually need 2 bridged outputs so an ideal part would have quad outputs I can use as 2 bridges.
Actually I got a TEA2025 dual amp which was spec'd as being able to operate off of 3.3v. I soon realized that was somewhat of an exaggeration, its outputs are pretty far from the rail on 3.3v especially at lower frequencies where the speaker has a lower impedance and thus needs to draw more current. It clipped rather easily. I need something closer to a rail-to-rail part.
Oznog is offline
Old 19th September 2006, 05:26 AM   (permalink)
National Semi and TI both have some pretty reasonable selections of speaker amplifier chips. Unfortunately most of the high performance smaller ones tend to be surface mount only (not much need for big DIP sized headphone/small speaker drivers). There's a couple stereo bridged drivers floating around in there, along with a couple 3 legged stereo headphone drivers...
Selection guides:
http://focus.ti.com/paramsearch/docs...ODE_STRY_PGE_T
http://catalog.national.com/Cat/jsp/national.jsp?i=119
hjames is offline
Old 19th September 2006, 06:33 PM   (permalink)
33mW should be more than enough, are you deaf or something?
Screen name: Aloone_Jonez
Hero999 is offline
Old 19th September 2006, 07:04 PM   (permalink)
104mW into 32 ohms, 2.7 to 5.5 volts
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5237
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 20th September 2006, 01:03 AM   (permalink)
High noise environment, and also the design of the headset does put the speakers a little further off the ears than usual.
Oznog is offline
Chip Identity edcross1 General Electronics Chat 5 21st July 2005 08:52 PM
Choosing proper interface chip vr Datasheet/Parts Requests 11 17th June 2005 10:51 PM
Converting 5V sinusoidal to 3.3V sinusoidal wave twinkleBell General Electronics Chat 9 31st January 2004 12:42 AM
What chip? Inputs and rs232 peetcool9 Micro Controllers 4 18th December 2003 11:37 PM
What chip to detect RF signals? Mr Red Electronic Projects Design/Ideas/Reviews 0 24th June 2003 04:46 AM
