| Notices |
| | (permalink (permalink)) |
| edit: Looks like I'm not suppost to post in this forum, sorry. Cant figure out how to delete or move the post. Ok so I've built up a few electronic kits , played with microcontrollers and digital circuts, but my basic understanding of electronic components is lacking. I have read a lot of stuff on this but I'm a little dense. Here's my questions. Does the voltage of a cap matter that much? Can I 'fill up' a 16volt with 2 volts? or will the capacitor top out and stop taking charge at 2 volts? OR, does the voltage listed for the capacitor instead represent the voltage at which it will discharge? Or am I just completely confused all together?? I'm trying to understand solar engines for beam robotics, and super caps for LED flashlights. any simple english for dummies type reply is greatly appreciated. Last edited by vampyre1000101; 18th September 2006 at 12:49 PM. Reason: I'm an idiot. | |
| | (permalink (permalink)) | |||
When you discharge the capacitor which we just charged from a 2 volt supply, the voltage from the capacitor will start at 2volts and drop exponentially to 0 volts (not mathematically correct, but this is the very simplified description). JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||||
__________________ L.Chung | ||
But, mathematically it never reaches zero. Practically, yes it does reach zero, as near as makes no difference. JimB
| Yeah, a 450v rated capacitor I took from my old monitor which had been left for about 6 months (so it must be fully discharged) was found to have 4mV or so in it. But for any sensible application this doesn't matter.
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| There are a couple of other things to consider. For example if the capacitor is charged with a constant current source the voltage across the capacitor will rise at a linear rate and not exponentially. On the same hand if the capacitor is discharged by a constant current load the voltage will also decrease at linear rate. The true diffination of the function of a capacitor is a device that opposes the change of voltage across it. So it charges and discharges to maintain the voltage.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
