Old 9th September 2006, 05:32 AM   (permalink)
Default Transistor in saturation mode
Iv been told that when operating transistor as constant switching devices, it is more efficient to operate them in saturation mode. it that right. Can any one tell me why that is?
fzn10 is offline
Old 9th September 2006, 05:45 AM   (permalink)
Which kind of transistor? BJT or MOSFET? Saturation means completely different things between the two.
For MOSFETs, yes, because it's the mode where the transistor is turned "on" the most with the lowest resistance (passes the most current).
Refer to the picture here:
http://en.wikipedia.org/wiki/Image:IvsV_mosfet.png
dknguyen is offline
Old 9th September 2006, 05:54 AM   (permalink)
its niether its called BD140, jsut a PNP silicon transistor. Does that theory for the MOSFET you just said still apply for that. THANKS
fzn10 is offline
Old 9th September 2006, 05:57 AM   (permalink)
No, it does not apply. THat is a BJT transistor. The two types of BJTs are NPN and PNP. The two types of MOSFETs are NMOS and PMOS. Saturation is unfortunately used for both devices but they are referring to completely different things.
[EDIT:] I think I may be mistaken. Although saturation means different operating modes for both types of transistors, they both happen to be the most efficient when being used as a digital switch.
http://ece-www.colorado.edu/~bart/bo...h5_3.htm#5_3_4
http://www.zen22142.zen.co.uk/Design/bjtsw.htm
I kind of forget how BJTs work so...yeah...read what I write critically.
dknguyen is offline
Old 9th September 2006, 06:42 AM   (permalink)
Yeah thanks, the second link acutally exaplains it all in the third paragraph
fzn10 is offline
Old 9th September 2006, 08:29 AM   (permalink)
dknguyen - you had it right the first time. Saturation in mosfets refers to constant current mode - where Id is independent of Vds. Triode region is the one you want when using a mosfet as a power switch - if you run through the equation and assume that Vds is very close to 0, you end up with Id ~= k*Vds which looks a lot like Ohm's law.
reference:
http://en.wikipedia.org/wiki/MOSFET
hjames is offline
Old 9th September 2006, 08:53 AM   (permalink)
Oh, so it is triode for MOSFETs and saturation for BJTs? I tend to get confused with the region where you switch between it's two extremes when using it as a switch and when you push the transistor way beyond the "on" threshold so it can't switch off as fast. Bleh, gotta review.
dknguyen is offline
