+ Reply to Thread
Results 1 to 11 of 11
Thread: AC coupling
  1. #1
    eng1 Excellent eng1 Excellent eng1 Excellent eng1 Excellent eng1 Excellent
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Default AC coupling
    I am using a bipolar supply with an inverting op amp. The input is a sine wave (5 V p-p) and its frequency can be as low as 10 Hz. I'd like to add a cap to eliminate the DC offset of the sine wave. The input resistance is 10 kohm.
    I could change this value and use a 1 uF non polarized capacitor... instead (and this is the question) if I add a 22uF elec. cap, how should it be oriented?
    EDIT: the sine wave swings between -2.5 and +2.5 V.
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,795
    As it's a bi-polar supply, and a zero referenced signal, there should be no polarising voltage across the capacitor - so either way should be fine, although it's preferable to arrange for a polarising voltage across electrolytics.
  3. #3
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,174
    Please post a schematic.
    if I know the answer.
  4. #4
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Quote Originally Posted by Hero999
    It's a simple voltage inverter. R1 = 10k ohm. The input signal is a sine wave swinging from -2.5V to 2.5V ideally, fmin=10 Hz. I need a high value for C, without changing R1, so I must use an elec. cap.
  5. #5
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,795
    As it's a split supply, and the input signal is referenced to zero volts, why do you need a capacitor at all?, simply DC connect it!.
    Or do as I answered earlier!.
  6. #6
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Quote Originally Posted by Nigel Goodwin
    After your answer I was asked to post a schematic.
    BTW this is an input stage and I don't know if other people will apply a zero referenced sine wave as I do... I didn't write this thought.
    If I add two diodes (without R2) in the feed-back path to make a zero crossing detector, any DC offset (small or large) is unwanted.
    If I can't predict the polarity of the DC offset, do I need to use a non polarized capacitor?
  7. #7
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,795
    Perhaps you better tell us EXACTLY what it's for?, as you keep changing the rules with almost every post!.
  8. #8
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Sorry, you're right. I thought to get a general answer for non-inverting configuration.
  9. #9
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    Since you want to capacitor-couple the input, then why is the input impedance so low as 10k ohms which requires an electrolytic capacitor for good low frequency response?
    The opamp has an extremely high input impedance with the FETs on its inputs, so use 100k or 1M rersistors. Then you can use a film non-polarized coupling capacitor with a lower value but still have good low frequency response.
  10. #10
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,174
    To minimise the effect of biasing currents you should connect the +input to ground via a resistor with the same value as R1 and R2 in parallel.
  11. #11
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    That is to balance the opamp's input bias currents. But the TL081 opamp he is usung has FET transistors at its inputs which don't have bias current.
+ Reply to Thread
Tags for this Thread
