Old 5th September 2006, 04:57 PM   (permalink)
Default Power supply advice
OK, aside from the usual taping-LEDs-to-batteries antics, this is my first serious foray into electronics and circuit design. I'm looking to be educated, so don't feel like you need to be gentle ;-)
I've got an LCD panel I'm interested in tinkering with. According to the spec sheet it draws 4.3W at 8V DC (peak). My first challenge is to actually get ahold of a reliable 8V DC power supply. I already have access to a perfectly adequate 12V supply (specifically, a 12V 1A wall adapter); my thought is to start out with that and hack up something that will give me 8V, and worry about fabricating a more direct power supply later. My eventual goal is a more-or-less self-contained unit, so variable workbench supplies etc. are out of the question.
What I'm not sure about is getting clean power at the required voltage. My back-of-the-envelope work indicates that a simple 2-resistor parallel voltage divider would produce enough heat to flame broil my apartment, so unless I really goofed the math, I'm figuring there's a better solution out there :-)
I'm working through my copy of "The Art of Electronics" and trying to sort this out as I go, but to be honest I'm running out of patience and itching to get my hands dirty.
So, the heart of the question - what's a good way to get the voltage I'm after? Some kind of zener setup? A regulator IC? Some other bit of wizardry I've not yet learned of?
Any/all input greatly appreciated :-)
ApochPiQ is offline
Old 5th September 2006, 05:22 PM   (permalink)
You are on the right path by using AoE - fantastic book.
Some points:
- your "12V" wall wart is probably not really 12V. It's unregulated so as the load increases, the voltage will drop. It *should* give 12V at what ever current it is rated for but don't count on it.
- you are correct about a resistive divider to get the voltage down. 4W at 8V is .5A. Get a voltage regulator and use your wall wart to feed it. 7808 fixed or a 317 variable will do the trick. datasheet has the schematics. it's just a couple of conmponents plus the Vreg. You will need a heatsink with that kind of current.
- I would oversize the WW current by at least 50% over the projected system draw.
good luck.
philba is offline
Old 5th September 2006, 05:53 PM   (permalink)
First, by starting with a wall wart or other pre-manufactured DC supply you are saving yourself some trouble as well as reducing the risk to yourself and others - in terms of electrical shock or fire.
If you have 12 volts and need only 8 volts then you need to do something to result in a 4 volt drop at your current requirements. Whether you use resistors or linear regulators (7808, LM317, etc) the result, in terms of heat, is the same. The regulator will keep the voltage relatively constant where the resistor offers no control. A switching regulator might be useful here but it's more complicated.
Whether 7808 or LM317, look at the datasheets to see what minimum voltage is required for a given output - for the 317 it's probably 2.5 volts or less. That suggests you need at least 10.5 volts input minimum at all times for the regulator to work. You might test your supply with some kind of load - possibly light bulbs from a car - so you can simulate 1/2 amp or so draw - then measure the output of your wall wart. You might also build the regulator circuit and just try it - measure the output of the wall wart before the regulator once you have your LCD panel connected. What you won't see are any momentary dips below 10.5 volts - though if the LCD works, that's what matters.
stevez
stevez is offline
Old 5th September 2006, 05:55 PM   (permalink)
I forgot to mention that a fuse following the wall wart, rated for the current limit of the wall wart or possibly 25% more might be a good idea. If the wall wart is rated for 1 amp and your load is 1/2 amp then fuse it for 3/4 or 1 amp.
Keep in mind that the current rating of the wall wart might be conditional - based on some duty cycle and ambient temperature.
stevez
stevez is offline
Old 5th September 2006, 06:09 PM   (permalink)
If your AC adaptor is can output more than 1A then I wouldn't worry about a fuse since the LM7808 will shut down if short circuited.
Screen name: Aloone_Jonez
Hero999 is offline
Old 5th September 2006, 07:04 PM   (permalink)
The fuse will protect from mistakes or failures between the regulator and the wall wart including any wiring. Now, some of the wall warts are protected as well however it is cheap insurance, in my opinion.
stevez
stevez is offline
Old 5th September 2006, 07:45 PM   (permalink)
his 12V WW, if rated for more than 500 mA will probably output something like 15V unloaded and 12V at the rated current. So, I suspect it will be fine.
If using a fuse, use a slow-blow one. The transformer will handle momentary overloads (it takes some time to get hot) and as hero pointed out, shut down happens at 1A or so. a fast blow fuse will be more of a nusiance than anything else.
philba is offline
Old 5th September 2006, 07:57 PM   (permalink)
If you want to play the "What if?" game then what would protect you if the wiring between the adaptor and fuse fails?
Hero999 is offline
Old 5th September 2006, 08:02 PM   (permalink)
The 'protection' that's already incorporated inside the wallwart, as with any use of a wallwart.
Old 5th September 2006, 09:05 PM   (permalink)
Have you considered modifying the 12V wall adapter ?
Inside you can probably trace the circuit and find a resistor divider between the 12+ output and ground. It will probably be fed into the 'Sense' pin of a linear regulator or switcher.
Try monitoring the voltage output, and bridging one of the reisistors with a 100k resistor to see if it affects the output.
You might be able to replace 1 resistor and turn your 12V into 8V.
.. but do try not to electrocute yourself.
1 0 1 1 0 1 0 1 1 0 1 1 0 1 0 1 1 0 1
StopGo is offline
Old 5th September 2006, 11:07 PM   (permalink)
But the protection often isn't resetable, once you've blown that thermal fuse you need to buy a new adaptor. Some use resetable bi-metal strips but not many I've seen.
Hero999 is offline
Old 5th September 2006, 11:17 PM   (permalink)
Cool, this is pretty much exactly what I was looking for.
Looks like I can pick up a 7808 for around 50 cents so I'll go ahead and pursue that route first. I've already set fire (literally) to a couple of wall warts with accidental shorts so I'll definitely be putting a fuse in the circuit as well :-)
As for modifying the adapter itself - I'd really rather not mess with it, at least not at this phase. Just getting the casing open would pretty much ruin the adapter (it's a cheap one) and even then my fine-detail soldering skills are pretty horrid, so I'm not comfortable trying to screw around with replacing resistors in there.
If this project goes where I want it to I'll need the ability to draw significantly more than the 550mA or so needed for the LCD, so I'll likely end up acquiring/building a switching supply to handle that. In any event though that's quite a ways in the future.
ApochPiQ is offline
Old 5th September 2006, 11:27 PM   (permalink)
If you're so concerned about losing the wall wart, and wasting money on blown fuses, use a Polyswitch rated for your application soldered in series with your transformer secondary leadout and wherever it was connected to in the wall wart, you will however, need to open it up to do that, something I would not recommend. As Nigel stated, in response to Hero999's comment about the wiring between the wall wart and the application, you're either at the mercy of the protection inside the wall wart, or sh1t outta luck, especially if it's a cheap unregulated supply. If it's a half decent regulated supply, there's a very good chance it already has thermal protection built in and should save it going in the bin in case of an accident, more so if it's one of the newer switching supplies.
tunedwolf is offline
Old 5th September 2006, 11:49 PM   (permalink)
Maybe for a regulated wall wart but most aren't. A typical ww is just a transformer, diode (bridge, probably) and a filter cap. There isn't any resistor to change. If the WW doesn't say "regulated", it isn't
You might be able to do it with a regulated wall wart IF you can get it open with out ruining it. I don't think it's worth it. By the way, you can get used WWs for a dollar or so from thrift stores.
philba is offline
Old 8th September 2006, 06:42 PM   (permalink)
Lightbulb
Why don't u buy a used PC power supply? Something like 2-3$ (I bought one for that price). Even an old AT/200W will give u 7-10A/12V. It has quite eficient overload protection. U can find info about wiring the source on diferent threads.
If is too complicated.....most of the times is the wrong way.
Tarsil is offline
