Hello all .. I have a problem need to make this to work on adc input my volt is (minus)-10mv to +65mv to smale to feed the adc what to do & howto do it /Kim | |
1) You need to use an inverting opamp with a dual supply voltage. 2) You add a +10mV offset voltage to the signal so that it is from 0V to +75mV. 3) You set the opamp for a gain of 5.0V/75mV= 66.67.
is Lm358 ok for this + 5v - 5v & can i finde a schematic for this here on forum | |
| | #4 | ||
Can't you make a simple inverting opamp circuit? Can't you add a single resistor for offset voltage?
__________________ Uncle $crooge | |||
| | #5 | |
Suppose your A/D accepts +/-5vdc. Then you need to "gain-up" the signal to approximately 76.9. Since your input is asymmetric, then your negative side will suffer some resolution degredation (what resolution is your ADC, and what precision do you desire?).. Lots of work here folks!
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | ||
| | #6 |
Yep thats right adc 0 - vreff (2.56) or 0-5 v in this is a atmel M8 (sorry) have made some atemt to use a 741 not good then 1458 (dual)gain to smal now i dont know what to do I only program software the electronic part in do by a frind but he is on hollyday for 2 weeks and this need to be done now cant wait the hard part is the (damm) -10mv kim | |
| | #7 |
A 1458 is a dual 741 opamp and will work fine with positive and negative 10V supplies. Their open-loop gain at low frequencies is typically about 200,000.
| | #8 |
If I use a 741 and add a pot 10k to pin 1 and 5 and to -10v is that not same at zero adj. ?
| | #9 | |
| | #10 |
Well I give up dont want to sepnd more time on this have to wait 2 weeks Tnx for the help (Analog) and audioguru .. | |
| | #11 |
Hmm !! now it work by using the LM358 (dual) gain ok offset ok and using + - 5 volt ( 5/1023) adc is 0 to 20502 at last .... Thats way I dont make electronic but only program software my skill in electronik is so damm bad ( sorry) | |
| adc, opamp |
