I apologise for what may seem an obvious question. Is a constant current source one that is constant regardless of its load? G | |
Yes, within limits. A constant current source will fall over if the load resistance is too high, as it will not be able to provide enough voltage to drive the desired current through the resistance. Good old Ohms law again. Similarly a constant voltage source will give a constant voltage regardless of the load, within limits. It cant feed the required voltage into a very low resistance, because it cannot provide enough current. JimB
![]() ok. Is this a constant current source? g | |
| | #4 | |
It will be temperature sensitive. The current will vary about -0.3% per degree C. | ||
Sorry so let me understand. If I move Rl to the collector it will be constant current source? Does anyone have any links to designs for constant current sources? Thanks Graeme | |
| | #6 |
Yes, look on the datasheet for the LM317 which is easy to find from Google.
| | #7 | |
| | #8 | |
| | #9 |
Yeah I do. But more importantly I want to improve my understanding. I've drawing a number of circuits which deliver a constant current irrespective of the input voltage but just realised that the current is highly dependent on the load which is really not what I want. I want a circuit that will deliver 300ma do any reasnoble load. If 300ma is not possible I want the most I can get. Id like to be able to construct the circuit using off the shelf components rather than buy devices. thanks for all the help so far. G | |
| | #10 | |
Do you know Ohms law? Do you understand op amps and feedback theory? Do you understand how transistors work? If you don't understand these, you won't be able to understand how current sources work. | ||
| | #11 |
I understand all these concepts. any help would be great. Graeme | |
| | #12 |
You can use op-amps and an n-channel MOSFET with a current sensing resistor and raise the supply voltage to the op-amp with a voltage doubler. This is a similar principle to the circuit I talked about in this thread. LM317T Adj. Voltage Regulator If you can't figure it out I'll do a basic outline of the circuit for you.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 1st September 2006 at 07:49 PM. | |
| | #13 | |
There are many other ways to make voltage-controlled current sources. | ||
| constant, current, source |
