| Hey does anyone knows why cellphones effluence on pc's monitors? the scaning lines freq in monitor is 15625Hz (or somthing around) the cellphones works on 800/900 MHz. can someone has a good explanation? | |
| ok, but why we see the influece of RF trasmission which is 800/900MHz, even if it picking it up, you shouldn't see it becaouse of high freq, am I wrong? | |
| Yes, you are wrong, providing the signal is strong enough the frequency make no difference, it will still cause interference.
| What you see on your monitor is happening to your brain cells... | |
| There are several ways that Radio Frequency energy radiating through space can interfere with other electronic devices. The most obvious one is if the other electronic device is a radio receiver tuned to the same frequency, and yet this is the most rare explanation. The most common form of interference occurs when the RF energy is turned into conducted voltage and current on a wire that is inadverdantly acting as an antenna. This RF power flowing on the wire is still at 800 MHz, but when it flows along the wire and hits the semiconductors in your electronics it gets converted to low frequencies through various processes including AM demodulation and through mixing with other oscillators inside the equipment. You see, most ICs, all diodes and all bipolar transistors contain PN junctions. These PN junctions are simple AM demodulators and when you put a high frequency EMF across them, they rectify the RF which converts much of the power of the RF to a baseband (low frequency) signal and this appears in your equipment. The stronger the signal the more you get baseband voltage appearing in your device. Many cellphones use the GSM communications standard for voice. This is a Time Domain Multiplexed system so your cellphone is transmitting with very rapid on/off pulses, it is not transmitting steadily. These pulses are being picked up by nearby wiring in the monitor and other equipment, they are being rectified and so you have electrical energy at the pulse frequency which is in the audio range, I think around 220 Hz. So if this happens to audio equipment you hear buzzing when your cellphone is transmitting. As most Ham Radio enthusiasts know, when you get interference of this sort, it is a sign that the device that is receiving the interference was not robustly designed. All governments issue radio licences to those controlling the radio equipment (in this case the cell system operator) which grants immunity to complaints of rectification interference. This immunity is not, however, extended to license-free radio devices (such as those certified or verified as Intentional Radiators under FCC part 15 in the USA) which includes most of the radio transceiver projects discussed on these boards.
__________________ RadioRon Last edited by RadioRon; 27th August 2006 at 12:29 AM. | |
| That's an excellent explanation Ron .
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." | |
__________________ 1 0 1 1 0 1 0 1 1 0 1 1 0 1 0 1 1 0 1 | ||
It's amazing just how small phones are getting these days. Won't be long before somebody will be able to superglue one to a rat's head and see how long he remains functional... I remember reading that the four main brain waves are measured in th 1-4 Hz range. | ||
| And your body is far too small to act as an antenna at that frequency. Radiowave are non-ionising radiation and can only damage you by heatin, all that stuff about mobiles causing cancer is pure rubbish.
Reminds me of the other classic fear, that of getting the bends if you go swimming shortly after eating food. No scientific evidence for it, but everybody knows its true, right?
__________________ RadioRon | ||
| Apparently electromagnetic waves do polarize your brain juices. Didn't you learn that in your electromagnetics class? Whether it is enough to concern you or not is up to you. | |
| | (permalink) | ||
Incidently, after heavy snowfall in 1990, we had no electricity, no water, and no phone for ten days - it was particularly annoying to hear the HV cables in the field buzzing and crackling away! - apparently they are part of the 'super grid', whatever that is?. However, I don't know how far the legislation goes?, behind me they are in an open field, so were easily moved. A friend of my daughter's actually lives directly underneath high voltage lines (300,000V) next to a pylon - but they haven't moved those, but it is in a housing estate and would be far more difficult (I suppose it's always possible they aren't used any more?). Quote:
| The 'bends' is expanding gasses in the blood while ascending to quickly (scuba diving). The abdominal cramps from eating before swimming... I was on the swim team from 9 years old, all through high school, never once a problem. A lot of leg cramps though, but that was probably another issue... Who funds the research? Usually a huge influence on the findings and disclosures. If you piss offyour employers, no more money, not to mention might effect future employment. Aren't the better research jobs, the ones where you aren't really expected to produce anything? Human body not big enough to act as an antenna? Why do people get struck by lightning then? What about metalic dental appliances? Not to mention the transmitter is almost embedded in most cellpone user's skulls. High tension power lines and transmitter towers are generally atleast 30 feet in the air... | |
