Old 26th August 2006, 12:10 PM   #1
Default easiest way to get +-12 volts from a car battery?
not sure how much current I need, probably 1 amp each should do it.
I know national semiconductors do a regulator, that with a switchmode transformer will give +-12 volts, but these parts aren't easy to come by...
I'll measure how much current I actually need at -12volts, it may not be that much.
also, +-11 volts seems to be enough anyway, as thats what the powersupply I'm looking to replace gives anyway.
cheers!
edit:
-12 volts @ 20mA is all I seem to need...
Death By Bass is offline
Old 26th August 2006, 12:41 PM   #2
+12 volts @ 30mA looks like it would be enough aswell
Old 26th August 2006, 01:12 PM   #3
This might do the trick, I made it once and it does work (was powering an op-amp)
http://sound.westhost.com/project95.htm
Angry!? I'm absolutely electrolytic!
Music web page:
http://www.music-playground.net/artist/drem/
Dr.EM is offline
Old 26th August 2006, 03:06 PM   #4
What are you building?
There might be a simpler way to convert your project so it will run of one single 12V supply.
if I know the answer.
Hero999 is offline
Old 26th August 2006, 11:52 PM   #5
its a home DVD player, that has +5 +12 and -12 volt rails...
the +-12 seems to only be for the circuitry... the +5 volts controls everything else, like motors and the display.
Old 27th August 2006, 11:08 AM   #6
You need a dc/dc converter module. Digikey and others sell them. You must also figure out the current requirements to size one.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 28th August 2006, 11:53 AM   #7
like I said... +-12 volts at under 100mA...
*looks around the room*
*pulls some PCBs out from under my bed*
hmm...
+5volts in, +-15 volts out? close lol
Old 28th August 2006, 12:58 PM   #8
Easy, add a LM7912 to the -15V supply.
Hero999 is offline
Old 28th August 2006, 09:46 PM   #9
be even easier to just buy a 10-15volt input, +-12volt output module...
rather than use the module I have, plus three regulators, and a handfull of capacitors...
Old 28th August 2006, 11:02 PM   #10
Looks like you've answerd your own question then.
Hero999 is offline
battery, car, easiest, volts
