| I have a neat little power supply that i made up. Here is the link to the schematics; Power Supply I have a 9Vdc @ 500mA power supply running into it. I just turned it on, and my z80 circuit booted, i then went to turn the manual clock on, and everything just, shut off? I immediately turned off the power switch. Now, when i try to turn it on, the 7805 gets REALLY hot REALLY fast. I did have a heat sink on it, too. What is the deal? I am guessing i blew it out.
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| Test the 7805 alone without the Z80 connected. A good 7805 will gives close to 5V at its output and remains cold without load.
__________________ L.Chung | |
| 7805 is hard to blow out due to load problems because it has a thermal limiter built in. If it is getting hot with a load attached, there is probably a bad load, like a short circuit.
__________________ RadioRon | |
| Oh my God! I feal soooo embarrassed! I found a short circuit! :embarrassed: My bad.
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| No. The thing gets very hot as it is. I know i am sucking A LOT of power from this baby. Soon, i am going to pull the power supply out of an old Apple 2e. I have the connector all soldered together, but i am just to lazy to pop the thing out. I rigged up a nice i686 fan onto it. I just have to figure out how to mount it? I am thinking Twist-Ties, or maybe cable ties? I don't know right now. I think i will go get that power supply! :cool:
| For what it is worth, I recently built a little 7805-regulated psu that I have successfully used for several projects. The attached shows it powering a two-digit counter that has been in continuous operation for a couple of months. I am using a Hewett-Packard wall-wart that is labeled 9 vdc @1000 mA. I have not had any heat problems. As can be seen, I do not have to use a heat sink. AllVol
__________________ All those who believe in psycho kinesis, raise my hand. Last edited by AllVol; 6th February 2007 at 01:49 AM. | |
| Then why on earth does mine get so HOT? I have literally burned my finger on the thing!
| I dunnough.... I have goofed up a few times and got things backwards. They got hot in a hurry, sometimes even to the point of extinction. Carefully check everything. Sometimes an error can be so obvious it looks correct. Allvol
__________________ All those who believe in psycho kinesis, raise my hand. | |
Assuming you do, then measure the current it's taking from the supply, and also measure the input voltage (don't beleive the spec on the PSU). | ||
| Yes, i have got the filter caps on the input, and on the output. I don't have anything to test it with, but the fan keeps it nice and cool now.
| I now, but i only have $5us right now. I used to have one, but i blew it out(long story). I know that the Z80 is a HUGE power hog. I am just going to connect a new power supply to it.
