Hi, Is there a way to amplify the input voltage from an antenna that receives 433MHz signal, using opamps i.e TLV2402 or 741? Does anyone knows a place in UK were its possible to buy Linear RF Power Amplifier ? | |
| | #2 | ||
In the first question - if you are asking if you can amplify the signals received by an antenna the answer is yes and it is called a pre-amplifier. If you want to increase the power going out of the antenna then Nigel's answers apply.
__________________ stevez | |
An old 741 opamp can deliver full output at frequencies lower than only 9kHz.
| | #6 |
Hi micael. Have a look at this: http://www.linxtechnologies.com/inde...ory=bba_series It's the BBA-332. I used this little pre-amp in a 900MHZ analog mic project, and it more than doubled the range. It has a +20dB gain and a gain flatness of +-2dB from 100MHZ to 2GHZ, so it should work well with 433MHZ. Although I'm not sure exactly how impedance matching works in regards to antennas and rx/tx, it has a 50 ohm input and output. It's about $10 on digikey. and best of all, it can't get much simpler!
| @433mhz, amplification, antenna, input, voltage |
