Old 16th August 2006, 04:05 AM   (permalink)
Default Regenerative braking and Gearing
Ok this might be a bit more on the mechanical side but, I want to do regenerative breaking with a go-cart. I have two gear-wheels with a belt drive. The smaller wheel is driven by the motor which effectively rotate a bigger gear-wheel through a belt which in turn rotate the wheels of the go-cart. Now iv read somewhere which iv referenced that you cant do regenerative braking due to some tension problems(look at reference under “toothed belts”. They only mention toothed belts however, but does that apply to chain belts (The ones used in bicycles for example) as well. Reading the theory about it, makes me think that it does, but just want to check
Referense
http://www.4qd.co.uk/faq/bmnc4.html#surge
located under toothed belts down the buttom.
fzn10 is offline
Old 16th August 2006, 04:54 AM   (permalink)
If you can drive your GoCart in reverse then you should be able to do regenerative braking as far as the belts are concerned. As long as you don't have an idler wheel (labeled as C) as depicted in the 2nd diagram, you should be fine. The idler wheel issue would apply to chains also. So, for example, a 10 speed bicycle drivetrain would not work.
kchriste is offline
Old 16th August 2006, 05:03 AM   (permalink)
what ur saying is actually is incorrect, the website is saying that the second diagram is actually a better option. Tnanks for ur input though.
fzn10 is offline
Old 16th August 2006, 05:05 AM   (permalink)
Just take the alternator off of a car, and then run it into the battery. Hook it up to a clutch, then it could be your breaks(make sure you have real breaks too!)
Marks256 is online now
Old 16th August 2006, 05:25 AM   (permalink)
Take a look at a beltdrive on a motorcycle.
kchriste is offline
Old 16th August 2006, 05:37 AM   (permalink)
An idler is supposed to be placed on the "slack" side of a pulley system. If the belt drive can go into reverse, that idler is suddenly going to be subjected to a whole lot of force that it probably wasn't designed to deal with - plus now there's going to be slack on the other side.
I've never really heard about this slipping issue though. Forces are forces, and I don't especially see why there would be anything special about backdriving a motor.
hjames is offline
Old 16th August 2006, 09:46 AM   (permalink)
'Real' motorbikes don't use belts!.
Old 16th August 2006, 01:32 PM   (permalink)
Funny, I never knew I was riding a fake motorcycle
OutToLunch is offline
Old 16th August 2006, 05:13 PM   (permalink)
Yes, Nigel. Most Harley Davidson's have a belt drive from the transmission to the wheel.
Old 17th August 2006, 10:03 AM   (permalink)
Like I said, 'real' motorbikes don't have belt drive!
Old 17th August 2006, 05:12 PM   (permalink)
Technically, motorbikes/motorcycles should be called enginecycles, or enginebikes. A motor is electric, and an engine is fuel powered.
So, what are you trying to say, Nigel?
Old 17th August 2006, 07:00 PM   (permalink)
Lol there are mopeds with chain drive!
I'd say a Harley is more of a motorbike than a moped!
Screen name: Aloone_Jonez
Hero999 is offline
Old 17th August 2006, 07:35 PM   (permalink)
All apples are fruit, but not all fruit are apples.
dknguyen is offline
Old 17th August 2006, 07:53 PM   (permalink)
I've never rated Harley's, high price, low performance - I've never seen the attraction of them?.
Old 17th August 2006, 08:45 PM   (permalink)
I can't say I like them either.
I prefer something lightweight and more sporty, I wouldn't swap my Honda CB500 for a Harley (apart from to flog on ebay, then buy a new CB500 with cash to spare).
Hero999 is offline
