What is a class D amplifier?
I know about Class A, B, AB, C amplifiers but never heard of class D Pls Help |
It is an amplifier that outputs a digital PWM signal. The amplifier is followed by a lowpass filter to filter out the highfreqency PWM but leave the signal created by varying the duty cycle of the PWM. The period of the PWM is higher than the signal you wish to amplify. These amplifiers have efficiencies of 90% or higher depending on the design.
"Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein |
Class C amplifiers have effeciency of greater than 95% so why do we need class D amplifiers????
(permalink) | ||
--- The days of the digital watch are numbered. --- Last edited by kchriste; 16th August 2006 at 03:37 AM. |
You can get a sine wave from class C, but you can't get more complex waveforms such as those found in speech and music.
A class-C RF circuit makes a sine-wave because it has a tuned circuit and works at only one frequency.
I guess we have all heard cheap car audio systems where the sub-woofer is tuned and makes "one-note bass" maybe with a class-C amplifier.
Uncle $crooge |
Furthermore, class c amps can and are used in high level AM systems, but they are used before the mixer/modulation step. In other words, it is more efficient to generate high power AM by amplifying the RF frequencies with a class c amplifier, then amplify the audio signal with a linear amplifier (in the right proportions of course), then mix filter etc. Please don't get me wrong, I'm only pointing out things that I found interesting while learning about different amps. I have a lot of respect for the wisdom and knowledge expressed in this forum by the likes of audioguru, nigel goodwin, kchriste etc. etc. the list goes on. I'm very much in the learning phase, as are many on these forums. I've been a hobbyist for about 15 yrs. but have never taken on electronics as a career, and as such, that is what my knowledge reflects. Happy learning everyone!! |
(permalink) | ||
I think he's talking about some large DSB AM transmitters which use a class C output stage; the power supply to this is fed from a large class D audio amplifier which modulates the output.
If you want to learn about class D amplifiers then Wikipedia is one of the best places to start. http://en.wikipedia.org/wiki/Class_D_amplifier
Yes, I clearly stated, as you quoted, that I was refering to high level AM modulation. But I was not refering to CW. DSB AM is also generated in this fashion. |
A 100Mhz FM station has a frequency swing from 99.925MHz to 100.075MHz at max volume. I call that one frequency because the 2nd harmonic at 200MHz and the 3rd harmonic at 300MHz are filtered out by the tuned circuit.
Uncle $crooge |
On a different note, aren't the harmonics of the carrier the easiest to filter out? What about the harmonics of the baseband signal? |
Uncle $crooge |
Your statement seems somewhat contradictory. Modulation is a multiplicative process and thus is not ever linear. When you mix two frequencies (not to be confused with adding or summing as in audio mixers) such that two new frequencies are created, you have removed all linearity.
