Old 23rd July 2003, 11:58 AM   #1
Default RCA signals
Can anyone please tell me the levels of RCA audio signals ? Also, I'd like to know if the signal is referenced to the equipment ground.
Thanks a lot
sbayeta is offline
Old 23rd July 2003, 01:07 PM   #2
RCA (or cinch) only a type of connector, no standard for audio level. (most of case the video in-out also RCA)
Some help if marked e.g. mic.-in, line in, tape-in, but the exact level readable only from device spec.
Try connect the audio-source, and when the output haven't distortion, the level is good. If the output volume too low, the input signal weak for input.
Sebi is offline
Old 23rd July 2003, 01:12 PM   #3
Thanks for your reply.
I understand what you're saying, but there must some de-facto standard for the audio signals that use RCA connectors, since you can buy a cd player, tape player or FM receiver from any vendor and connect it to any other vendor amplifier without worrying about the signal levels, the impedance, or the grounding, right ?
sbayeta is offline
Old 23rd July 2003, 01:30 PM   #4
Yes, don't worry, just connect it.
Sebi is offline
Old 23rd July 2003, 01:39 PM   #5
Hi again,
I need to know the signal levels, ground reference and impedance because I'm working in a little project, which has an audio interface.
sbayeta is offline
Old 23rd July 2003, 03:30 PM   #6
As stated by others, the connector does not define the signal level. RCA connectors are often used on what I've come to understand is "line-level" outputs or inputs. I think "line-level" is 1 volt peak to peak - at least that is what I have come to understand.
stevez
stevez is offline
Old 23rd July 2003, 09:54 PM   #7
You DO have to worry about levels and such when you're buying audio equipment.
My head unit in my car has 4v pre-outs (RCA's)
My amplifier has adjustable inputs, 250mV to 8v. There is a gain control knob, I set it to 4v to match my head unit.
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who.
A recent study shows that research causes cancer in rats. -- I dunno who said that one either.
Noggin is offline
Old 23rd July 2003, 11:41 PM   #8
I seem to remember that line level audio is 1mW into 600ohms. I may be wrong because I've not used it for a long time.
pebe is offline
Old 24th July 2003, 12:33 PM   #9
I found a site (actually refers to WABC radio station) and there was a good explanation of "line level." The author refers to an obsolete standard though it may be defined in a current standard. Line level was said to be 0.775 Vrms into 600 ohms which is also the basis for 0dBu, a point of reference. 0.775 volts works out to be 1.0975 volts peak (not p to p) and it appears that many users often shortcut to 1 volt peak (which would then be .707 Vrms if it were a sine wave). Interestingly enough other references were made to "line level" as being between 0.3 and 2 volts.
So, if RCA connectors are used as output on an audio device it might be line level (as described above) or it might be something else. I noticed numerous web pages on how to deal with the various levels.
stevez
stevez is offline
