+ Reply to Thread
Page 6 of 12
First ... 2 3 4 5 6 7 8 9 10 ... Last
Results 76 to 90 of 170
Thread: Press-n-Peel PCB problem
  1. #76
    gaurav_sharma132 Newbie
    Join Date
    Jul 2008
    Location
    India
    Posts
    51
    Post
    ohh man that a very nice trick...Thnx for it first.
    Then simply put it on the copper clad and press it for 5-10 min???
    Magazine paper leave a good trace on copper clad after peeling it off ??
  2. #77
    BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,193
    Quote Originally Posted by gaurav_sharma132 View Post
    Press it with an iron, but 5 minutes seems too long. I think probably around 3 minutes, but I use a laminator, so have not done it this way for quite some time.
    Don't try to peel off the magazine paper though. Soak the thing in warm water, perhaps with a drop or two of soap, for a few minutes. It should come off fairly easily, but you may have to scrub off some paper residue with a toothbrush. Be gentle when you do this as you can scratch off your traces.
  3. #78
    Join Date
    Jul 2008
    Location
    India
    Posts
    51
    Dude as you have experience making PCB by using magazine paper...so can you Please enlist the steps from beginning as I am going to make it for the first time.....
    Thanks in Advance
    Regards
    Gaurav Sharma
  4. #79
    3v0
    3v0 is online now
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Quote Originally Posted by Rolf View Post
    I would not know because I only use P&P and I have no problem with 0,006" lines!
    And this is not hearsay.
    Is what you are saying that Pulsar is consistently producing lines finer than 0.006"?
    PCB "Fab-In-A-Box" ... The 8min circuit board system
    Now using any standard 1200 dpi laser printer and the TIA applicator, you can image down to .006" (and below!) We've had customers who have reported traces down to .004"!
    I would not call this hearsay. The guy who runs pulsar is very up front.
    To date i have been happy with .01 and larger traces. Maybe as I get into the fine pitch stuff I will go smaller. I personaly have not tried .006 and .004, played with .008 but never used them in a project. At some point it depends on what the laser printer can do.
    BCHS/3v0's Tutorials
  5. #80
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,193
    Thanks in Advance
    Regards
    Gaurav Sharma
    Basically:
    1. Print the image to paper
    2. Transfer the image to the copper surface using an iron or similar
    3. Remove the paper by soaking the board
    4. Etch the board to remove all exposed copper
    5. Remove the toner circuit image with acetone... done!
  6. #81
    3v0
    3v0 is online now
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Make number 3 soaking.
  7. #82
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,193
    Quote Originally Posted by 3v0 View Post
    Thanks, and thanks for putting the link in - you do know where I lifted the list- just too lazy to type one up myself.
  8. #83
    Join Date
    Jul 2008
    Location
    India
    Posts
    51
    hi guys,
    Tell me one thing that should i drill holes before etching process or after it.
    which is preferable or why ?
    Regards
    Gaurav Sharma
  9. #84
    Rolf Good Rolf Good Rolf Good
    Join Date
    Jun 2006
    Location
    E. Tennessee, USA
    Posts
    652
    hi guys,
    Regards
    Gaurav Sharma
    If you try to drill first the heat from the drill melts the toner and gums up the drill bit.
    Drill after etch and toner removal and the center hole will help you guide the drill.
  10. #85
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,193
    I agree with Rolf, except I usually drill after etching but before I take the toner off.
    If you are working in EAGLE CAD, run the ulp called 'drill-aid' from your ulp scripts. It will make all the holes smaller in the center and much easier to drill.
  11. #86
    Join Date
    Jul 2008
    Location
    India
    Posts
    51
    firstly, thnx for reply...
    And dude i am using proteus it is very good software as it also have capability of simulation of the circuit in addition to PCB design.
    But I dude I have read somewhere that It is preferable to drill before etching is started because the surrounding copper gives better mechanical strength to round pads around the drilled holes. These pads may be ripped off sometimes when drilling after the board is etched. Another good reason is that the etching after drilling would remove any strands of copper around the edges of the drilled hole.
    Is it true ??
    Regards
    Gaurav Sharma
  12. #87
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,193
    Is it true ??
    Regards
    Gaurav Sharma
    I learned that it is preferable to snip your component leads before soldering because the stress the cutter puts on the lead degrades the connection. I still snip my leads after soldering, though, as it is a lot more convenient to do it this way. I don't know many people - perhaps there are some - who do it the 'proper' way.
    I would build a few boards and try it both ways.
    If you over-etch the board, and the traces get undercut, then there is more chance of tearing off a small pad with the drill. Make your pads and traces as large as you can, then they will be sturdier. The boards I make are designed to be made at home. I would use thinner traces, etc. if I were submitting a board to be made commercially.
    Hope this answers your questions.
  13. #88
    Join Date
    Jul 2008
    Location
    India
    Posts
    51
    Post
    Is photo paper is ok for the method of applying heat to copper clad by domestic press???
    Regards
    Gaurav Sharma
  14. #89
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,193
    Regards
    Gaurav Sharma
    Hmmm, what do you mean by photo paper?
    Just find a glossy page in a magazine with the least amount of print on the page and use that.
  15. #90
    Join Date
    Jul 2008
    Location
    India
    Posts
    51
    Actually, Dude me not having printer at home.....
+ Reply to Thread
Page 6 of 12
Tags for this Thread
