| Here is photo I just made of exactly the same amp as we are talking about. I use it with my AM-FM tuner. It is the device on perfboaard on the top left of the tuner. As you can see, I am using only an input cap (the light blue one) and an output cap. It drives speakers with all the volume I want, and more than my wife and others in the house want. Some day, when I get to it, it will be put inside the tuner case. Believe me, your circuit will work.
__________________ All those who believe in psycho kinesis, raise my hand. Last edited by AllVol; 6th February 2007 at 01:48 AM. | |
| what about the disc cap is that the .05 uf one because i used a polyester caps that is green and the condenser mic i got is a condenser mic element is that ok? | |
| Hi Ghost, Yes you should be okay with all. The 386 is very forgiving... maybe that's why I like it so well. The little disc cap is just a by-pass. You'll notice I didn't even have to use a large cap by-pass on the power rails, although that is a good idea. Good luck, AllVol
__________________ All those who believe in psycho kinesis, raise my hand. | |
| The LM386 amp circuit won't work with a condenser microphone. It needs an electret microphone that is a condenser mic with a built-in high voltage charge. Make sure that the electret microphone has two connections because ones with three connections need to be connected differently. The metal case of the mic is connected to its ground wire and the other wire is its output. AllVol, With a 9V supply, an LM386 amp delivers only 450mW to an 8 ohm speaker at clipping. My home stereo delivers 70W to 8 ohms or 120W to 4 ohms per channel at clipping.
| my mic has a red a white and a ground | |
| Connect the red to +V, ground to 0V and the white to the input of the amplifier.
| where does the battery connect to | |
| donty u mean connect the white to the 1.0 uf ![]() | |
| if i dont use a ground can i just connect all ground sybols to each other | |
| You need a ground, otherwise it wont work. Also, i don't mean to be rude, but there is no need for double, or even triple posting. If you accidentally forget to add something, there is an EDIT button at the bottom right of your post. | |
| in the pic what represents the batt | |
| The datasheet for the LM386 shows an RC network (zobel) at the output to ground to stop it from oscillating when the inductance of a speaker causes a high impedance load at high frequencies. With your 3-wire electret microphone, remove the 2.2k resistor. Battery, what battery?? Does the circuit need a battery?? Why??
| The circuit doesn't assume you're running it from a battery. It could be powered from a mains adaptor, a battery or even a solar panel. It's common place to just put power nodes in schematics, in this case connect Vs to the positive terminal and the ground symbol to the negitive terminal.
| do u mean connect all the ground symbols to the negative also, the positive and negative terminals on wat the batt or the chip wait it just hit me that last post u made. so u mean just connect the gound to the negative of wat ever is powering it and connenct the two Vs nodes to the postative of whatever is powering it right? Last edited by Electro-Ghost; 13th August 2006 at 05:34 PM. | |
| Exactly! But I'll show you just to be sure. Drawing circuits with power supply nodes rather than batteries helps save space and make them easier to read.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 13th August 2006 at 05:41 PM. | |
