Old 13th August 2006, 12:47 AM   (permalink)
does anyone knoe where i can get a mega phon circuit schematic w/ instuctions
or at least a part list
Electro-Ghost is offline
Old 13th August 2006, 12:50 AM   (permalink)
Yes, a megaphone is an amplifier. You don't need a parts list. ALl the values of the parts in your schematic are labelled and show you the values you need. The op-amp also has a number. Just put the circuit together and (I presume) connect the output to some speakers. You may need a small transformer to match to match the impedence of your circuit with the impedence of speaker.
dknguyen is offline
also i got a potentiometer with a built in spdt switch and it has 6 soldering terminals 3 at the locatation theyre normally at and 3 on the very bottom. what are the three on the bottom for
Old 13th August 2006, 12:53 AM   (permalink)
My guess is that the 3 terminals are for the SPDT switch. YOu did say the potentiometer had a switch built in.
dknguyen is offline
Old 13th August 2006, 12:56 AM   (permalink)
i also forgot to mention i substituted a 47 uf capacitator for a 33 uf and a .047 uf for a .05 uf and a 244 uf for a 250 uf
Old 13th August 2006, 12:57 AM   (permalink)
i have never seen a spdt switch with 3 terminals though
Old 13th August 2006, 01:01 AM   (permalink)
By definition a SPDT switch always has 3 terminals.
http://en.wikipedia.org/wiki/Switch
What you thought was a SPDT switch was not one.
You probably can substitute the capacitors. It depends on the circuit. I can't see anything horrible happening if you substitute in this circuit.
dknguyen is offline
Old 13th August 2006, 01:02 AM   (permalink)
Yes, Single Pole Double Trough. This means one in, two outs, or two ins, and one out. Very common and useful switch! :cool:
Marks256 is offline
Old 13th August 2006, 01:05 AM   (permalink)
Originally Posted by Electro-Ghost
mine doesnt
It is very difficult to make one NOT work. If there is an AM broadcast radio station near you, you can pick it up simply by touching a wire to the ungrounded pin 2. You should hear audio through your speaker. In most cases, the cap between pins 1 and 8 is optional, only used to increase gain. If you are having trouble, and you have the device wired correctly, I should think your problem is in whatever you are using for input, whether it be electrec mike or other source.
All those who believe in psycho kinesis, raise my hand.
AllVol is offline
Old 13th August 2006, 01:06 AM   (permalink)
i didnt hook anythin up to those 3 terminals
Old 13th August 2006, 01:14 AM   (permalink)
i also forgot to mention i substituted...
No problem, as long as your 47uF and 244uF are electrolytics.
AllVol is offline
Old 13th August 2006, 01:17 AM   (permalink)
i am uusing a condenser mike
Old 13th August 2006, 01:24 AM   (permalink)
im usin a 9v battery to power it
and i didnt ground any of that stuff i just connected all the things that were supposed to be grounded together
Old 13th August 2006, 01:25 AM   (permalink)
actually im usin a 220 uf
Old 13th August 2006, 01:28 AM   (permalink)
my speaker is a 8 ohm 1 1/8 diameter mini speaker
