Yes, exactly like that; connect the enable line of one demux up to the to the MemRQ and the enable line of the other to the IORQ line from the Z80.The only thing i still don't understand yet, is how to select memory or i/o. Should there be another mux/demux? Would i connect the enable lines of the demux's up to the to the MemRQ and the IORQ?
It is possible to use a diode matrix and a demux wired to the lower address lines to create your own ROM, but that would be very painfull to do. You can also play around a bit by rewiring some of the resistors on the databus to +5V instead of Gnd. You'll see a change on the address LEDs flash pattern.was wondering, is it possible to add a DIP switch to the data lines, and then hard wire a program?
This is one site that looks easy to use:Sounds like it might be fun. How would i figure out what the commands are in binary?
http://www.cantrell.org.uk/david/tec...re/z80index.pl
This site gives a brief decription of each instruction:
http://fms.komkon.org/comp/CPUs/z80.txt
Thanks kchriste!
I am going to order the components tomorrow(Monday). This is what i have on my list so-far(All prices are in US currency);
