| :idea: im working on a project and i need a circuit to drive a 8.63v (9v)bulb really brite maybe a 1000mA more or less.using one or two 9v batteries for supply i was trying to use the transformer from a camara flash a npn transistor a capacitor and some resistors.but the fact is i don't know what the hell im doing any help is much apprieciated thanks.
__________________ Fight for the freedom of yourself and others,But do not hesitate for the enemy draws near.For my wrath is furious and my judgement is harsh,The Enemy shall be no more. - John Manuella | |
| What kind of bulb is it ? If its an incandescent one you can very easily blow them up by over-powering them. The current through the bulb is limited by the bulbs resistance. So to get lots of current through it you need more voltage to overcome the resistance...... And too much current means youll get a *reaaalllly* bright flash, for a fraction of a second then your bulb will pop Really depends on what type of bulb you wish to light though. -Chris | |
| Right. 9 volt/DC bulbs are rated for brightness - just like the AC bulbs you use around the house (you know, rated in watts). If you want a bright bulb, you buy a bright bulb. Overpowering your existing bulb with a big powersupply will result in a really bright bulb for less than 1 second (e.g., using two 9-volt batteries will just blow out your bulb) | |
| A little more information would be helpful. It is possible to overvolt LEDs for milliseconds before dropping the voltage/current to within normal values for the remainder of the cycle. This is done with an IC or homebrew circuitry that charges capacitors so that the current/voltage for the overvolt portion is available when needed - charging of the capacitor(s) is done during the "off" part of the cycle so the arrangement presumes that the light is going on an off. Note that the folks who figured out how to do this probably ruined a fair share of LEDs before coming to a value that allows reasonable life and the desired brightness. For what it's worth a camera flash typically uses high voltage and low current - it would seem unlikely that the camera flash output would be any use on a 9 volt bulb (unless the bulb has failed and you get a spark to jump). Give us a little more detail about what you are trying to do. Experimenting can be fun and educational but remember that safety is important.
__________________ stevez | |
__________________ Fight for the freedom of yourself and others,But do not hesitate for the enemy draws near.For my wrath is furious and my judgement is harsh,The Enemy shall be no more. - John Manuella | ||
| thanks,and yes safety comes before all,it's for a toy and deffinatly has to be safe.it's just that the light from the bulb is too faint,i thought a circuit could increase the milliampheres a bit to increase the brightness of the incandecent lamp,i tried a number of bulbs,and this is the brightest i could find for 9v.
| Kiss method. keep it simple (stupid) hehe just get a higher voltage / wattage lamp and use more 9v batterys. otherwise, why do you need suck a bright light? what the matter with using several flashlights ducttaped togehter? why it the final goal for this?
__________________ Do no meddel in the affairs of dragons, for you are tasty and go good with ketchup. | |
