I've got a security system that is giving me a "low battery" alert. I measured the gel-cell battery (unloaded) at 13.64V. The battery leads from alarm are showing 13.75V (110 mV difference). I assume this is sufficient difference to kick off the low-bat warning since the gel-cell hasn't charged up to that. I don't really understand lead-acid battery charging in great detail, though.
I know I'd need to cycle test the battery but is it reasonable to assume that the battery is going bad? It is only 5 years old. The environment is a heated basement and it's done maybe 5 full cycles in its life (though none recently). It seems like it should give me longer life than that. should I be looking elsewhere for a problem? I'll replace it since that's the cheapest option but it does seem premature. the security system is a gemini |
It sounds a little overly sensitive?, that doesn't sound very low to me?.
However, you say it's 'only' 5 years old - how frequently are you supposed to replace it as part of the annual maintenance?. |
What's the normal battery voltage?
Most security alarms have a 12 Volts back up battery in it in case the power is off for a period of time.
If the mains is present the voltage will be around 13.6 to 14 Volts. The low batt alarm should not come on when the battery is being charged anyway, which means the voltage is over 12.6 Volts for a lead acid battery at rest e.g no load applied. In your case if the battery is over 5 years old i would consider replacing it. Sometimes these older batteries get a weak cell which draws the voltage down permantly or intermittendly. For the sake of a 40 $ NZ 25 $ US battery (12volts 7 Amp hrs)or godd security that money is well spend to replace it. If you check the batt with a load 12 volts lamp 21 Watts, and the voltage at the terminals drops well below 12 volts rapidly, replace it. On your new battery write the date on it, before putting it in.
There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. |
Just throwing this out there........
Many alarm systems have wireless sensors, such as a remote fire/heat sensor, or a sensor located in the attic, etc or sometimes just where is would be a pain to hard wire. Even some "wired" systems can have one remote wireless sensor. Anyways, the point of my rambling is that some systems will report "low battery" when its the wireless sensor that has a low battery, not the main unit. The gel cell should, once settled, sit at about 12.8 volts when fully charged. |
by the way, good call on the price - 24.99 $us. Last edited by philba; 31st July 2006 at 09:59 PM. |
Are you really sure it's a 12V and not a 15V battery?
wierdest question I've gotten in a while... |
Why is that so strange?
If it's a 15V battery then of course it'll give a low battery signal at 13.75V.
where might one find a 15V gel-cell? especially for a standard device like a security system. sure it's possible but so are lots of other voltages that they don't make.
by the way, I may not know a lot about lead-acid cells but i do know that a 12V lead acid battery is usually charged to around 13.75V or higher. a 15V gel-cell (if they exist) would probably get charged to 17 to 18V. also, the issue isn't unloaded voltage but rather the battery's behavior under load as was mentioned above. once i put a small load on it, the truth came out. |
My maintenance dept. has just changed out around fifteen 12v - 7ah gel cell batteries used for backups to the control electronics for the HVAC systems. They pretty much all measured 13 to 13.7 volts but many of them could barely illuminate a small 12v lamp used as a test load. Even after charging them, and rejuvenation, they still didn't hold a charge very long. So the voltage reading (unloaded) is somewhat meaningless. I did experiment with a couple of them by prying off their sealed top covers to expose the individual cells. I removed the rubber caps, injected a small amount of distilled water into each of the six cells and replaced the covers. Throw it on the charger at a slow rate and voila! The battery has sprung back to life but still not like a new one. I have kept a few of them to use around my home for running two-way radios portable-like during a power failure.
Don't make me reach through this monitor to slap you a good one! |
Never heard of 15 Volts security alarm systems or batteries.
As Nigel sais 7½ cell batteries don't exist. Most standard domestic alarm systems are 12 Volts dc. The batteries under charge can go up to about 13.8 Volts.
