Old 27th July 2006, 07:53 AM   (permalink)
Default why must the matching impedance be 50 ohm
I understand that for maximum power the input and output impedance must be match. But I dun understand why most circuits have to be matched to 50 ohm, can anyone care to explain the reason behind it? What is the reason for most circuits to have an input impedance of 50 ohm, why is it other values like 60 or 70 ohms.
fstspec is offline
Old 27th July 2006, 10:39 AM   (permalink)
Circuits definately arn't all matched at 50 ohms. Telephone systems are usually 600 ohm. Which circuits do you find as 50 ohm?
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline
Old 27th July 2006, 12:19 PM   (permalink)
As already stated, impedances should match for maximum power transfer. In some circuits the behavior of the connected circuits can be profoundly impacted by a mismatch. The final amplifier of a transmitter can self-destruct because it's output is mismatched. As I understand it, filters may not perform as intended if not matched.
Do a little reading on transmission lines and you'll see how the size of conductors, spacing and other things, affects what is known as characteristic impedance. If you focus on coaxial cables you'll see that coax can be (and is) made in 50 ohm impedances as well as others - 75 ohm, 93 ohm, etc. What the industry did at some point was realize that for various applications the output impedance of an item should match the available coaxial cables. 50 ohms, for many situations, has been found to be an acceptable design point for the cables so the equipment has to match. For many things, like cable tv, 75 ohms or so is the standard - because in this type of application the 75 ohms is a better compromise in terms of behavior.
stevez
stevez is offline
Old 27th July 2006, 12:34 PM   (permalink)
I still don't trust that my posts will make it so I broke this up.
Think about this example - an RF transmitter feeds a 50 ohm coaxial cable - therefore the load must behave like 50 ohms for a proper match. At 200 watts there will be 2 amps current flowing with 100 volts between the coaxial conductors. If we designed our system to use 450 ohm line we'd have 0.66 amps of RF but now we've got 303 volts across the conductors. I use this to illustrate that voltage and current levels do change and that can drive some choices.
stevez
stevez is offline
Old 27th July 2006, 12:39 PM   (permalink)
Too add further confusion (or clarity) the voltage between the conductors in my prior example only holds up if things are matched. In a mismatched condition the voltage at some points on the transmission like can be many times the matched voltage (too much to explain here). That can and does cause failures in components, transmission lines, etc.
stevez
stevez is offline
Old 27th July 2006, 01:48 PM   (permalink)
I just took an Electromagnetic Theory course for my major and we went over the fine details of matching the impedances. Trust me, matching is important. And I will never take that painful course again lol.
Ambient is offline
Old 27th July 2006, 03:22 PM   (permalink)
Ambient: I bet you now know exactly what that funny little P-R key does on your calculator.
here is a link to an explanation of Characteristic Impedance: http://www.allaboutcircuits.com/vol_2/chpt_13/3.html
Nice work stevez.
zevon8 is offline
Old 27th July 2006, 05:37 PM   (permalink)
Geesh!... why people don't use google, I don't know.
Here is one explanation of why.
http://www.microwaves101.com/encyclopedia/why50ohms.cfm
Optikon is offline
Old 29th July 2006, 09:49 AM   (permalink)
Hello everyone
About 7 or 8 months ago, I did exactly what you said Optikon. I typed a question regarding electronics into Google. To my pleasant surprise, I found the answer to my question (through Google) right on this website, where I also found a large community of friendly, and social, like minded individuals who enjoy sharing their vast knowledge. When it comes to people coming on here and expecting someone else to complete their school projects or other large projects, then I agree with you wholeheartedly. However, I have no problem with people posting to ask general questions about electronics theory, etc. Isn't that why we are here: to learn from each others experiences, and to interact with real people instead of just reading technical papers online? I'm not trying to flame anyone here, I just thought that's what this forum is all about. I have a lot of respect for all of the experienced folks on here who have been doing this stuff for many years now, but continue to educate people post after post, even if it does get somewhat repetative sometimes. Thanks to everyone for a wonderful forum.
Sig239 is offline
Old 29th July 2006, 10:23 AM   (permalink)
Hello fstspec
There are some instances when you don't want maximum power, and therefore don't want the impedences to match. An oscillator is an example of this, since if you draw too much current from the tank circuit, you will sacrifice stability and reliability. In this case, you "loosely" couple to the tank circuit.
Now ask yourself this. Is directly shorting a battery the way to draw the most current? HMMMMM... Have fun!!!
Sig239 is offline
Old 29th July 2006, 11:15 AM   (permalink)
Originally Posted by Sig239
Hello fstspec
In MOST instances you don't want matched impedances (and it would be a REALLY bad thing!), but you do need to be aware of the small number of cases where it's ABSOLUTELY VITAL to match impedances (such as RF amplifiers).
Incidently, shorting the battery wouldn't produce maximum power, because you're not matching it's impedance (or more correctly, internal resistance).
Old 29th July 2006, 11:46 AM   (permalink)
To get maximum power from the battery the load impedance would have to be the same as the internal impedance of the battery so the efficiency would only be 50%.
Just thinking, why have I seen transmitters with a higer efficiency than 50%? Could it be because the impedance of the output stage isn't resistive so it doesn't disipate any power?
Screen name: Aloone_Jonez
Hero999 is offline
Old 29th July 2006, 03:10 PM   (permalink)
Originally Posted by Hero999
Just thinking, why have I seen transmitters with a higher efficiency than 50%? Could it be because the impedance of the output stage isn't resistive so it doesn't disipate any power?
The output transistor can be operated in class-C so it conducts only part of the RF wave, and it can switch fully-on and fully-off. Then the tuned LC tank turns the rectangular-wave current into a pretty good efficient sine-wave.
audioguru is offline
Old 29th July 2006, 06:34 PM   (permalink)
I'm aware of that, but you can by an RF amplifier with an output impedance of 50ohms and it's 60% efficient. How is this possible when the when if for maximum power transfer the load must be 50ohms and it'd be only 50% efficeint?
I presume that the output really isn't 50ohms, it's just designed to drive a 50ohm load, is this correct?
Hero999 is offline
Old 29th July 2006, 07:02 PM   (permalink)
No, I would suggest it's simply "playing with the figures", and isn't really more than 50% efficient at all!.
A lot depends on exactly what type of transmitter it is, and how it's measured - the DC input to the final output stage is one VERY easily measured figue, and is one way of specifying amateur radio transmissions. For SSB you use PEP - 'Peak Emitted Power' - which is a far more difficult thing to measure.
