| I have a recently built lab in my basement. I finished a small area set aside as a storage room. It has shelves, benches, heat/cooling/dehumidfier and plenty of storage for components as well as whole equipment. I've worked in shops/lab most of my life but never had a nice lab at home. So I buckled down last winter, designed and built one from scratch, including the storage shelves, benches, and cabinets. I have is acoustically insulated to the point that I can hear electron flow inside a transistor!!
__________________ Don't make me reach through this monitor to slap you a good one! | |
| Dean, Thanks for the tip! So far I've just done the quick and easy work and pulled socketed IC's from the boards. I haven't needed any soldered ones yet except for some TO-220 regulators. Eventually I may pull off the IC sockets, as they're all very nice gold plated machine pin types. We have a desoldering pump at work that is great for pulling off parts with many pins. I've also been cutting off the gold card edges and saving them. a few pounds of these sell pretty well on eBay to people who use them for gold recovery. | |
| I don't think he heard you.
__________________ All those who believe in psycho kinesis, raise my hand. | |
| I do the oposite then soundprofing it.I put in a radio so there is no silence.I dont like being in total silence for extended periods.
| Really old and I mean early 60's IC and how many 60s ICs were there anyway, had a lot of gold in them. While browsing thru a telegraph exchange that was being bulldozed I came upon across some circuit boards with ancient ICs on board, the top of the ICs was a white clip-on cover and when removed you could see the gold wires to the pins each with a different coloured varnish. The main part of the IC was in a ceramic type encapsulation. the pin numbering was also differentit went top 1 2 3 4 5 6 really, really old I donated them to the Communications museum | |
| Dean, you bring up a good point and although I didn't mention it, I remove just the more common use ICs while leaving the boards in a box. Yes, ESD can be a problem and they are better left mounted to the board, also making it easier to quickly scan a board for a needed chip, versus rifling thru a parts drawer of them. Someone Electro, The reasoning behind having a quiet room is to better hear horiz. oscillators in a television to confirm they are working, as well as listening for other low level mechanical sounds in problem equipment. For the most part, a television or stereo is running off side for entertainment. And that can be a real distraction just like it was last night as hot solder dripped off the pencil onto my leg ... nice blister!!
