Old 5th July 2006, 09:33 PM   (permalink)
Default A/D Parallel output to 7 Segment
I will be using an ADC0801 A/D converter for a small project, the output is Parallel (Db0 to Db7). Is this the same as BCD? What I plan to do is to interface it to a BCD to 7 segment IC, but will it work?
I figured it would since BCD, and parallel output are the same, they are of course binary.
Overclocked is offline
Old 5th July 2006, 10:18 PM   (permalink)
Binary Coded Decimal is from 0 to 9. 8 bit binary is 0 to 255. It will work all right until you get over 9, then you will get fictitious numbers.
ClydeCrashKop is offline
Old 5th July 2006, 10:23 PM   (permalink)
You need to reset it after 1001 with a gate .
oldtimer is offline
Old 5th July 2006, 10:52 PM   (permalink)
BCD and binary are most assuredly not the same. Unless the A/D converter has BCD outputs your proposed design is doomed.
Papabravo is offline
Old 5th July 2006, 11:19 PM   (permalink)
You could always make a BCD Encoder for the output of the ADC. As a side-issue, bear in mind that the ADC0801 is designed mainly for use with a microprocessor. That doesn't mean you can't use it as a standalone device - you can and it'll work fine, but you'll want to look up the timing diagrams on the datasheet because you've got to connect it up in a certain way to get it to work on it's own. I managed to figure it out when I used one as a standalone so if you get any problems I'll have a quick look at the datasheet for you - I'm sure I can figure it out again!
Brian
ThermalRunaway is offline
Old 5th July 2006, 11:24 PM   (permalink)
Hang on, something's telling me it was an ADC0804 that I once used not an ADC0801. So I might be wrong about the whole micro interface thing.
Brian
Old 6th July 2006, 01:35 AM   (permalink)
Brian
Luckly for me, I found a chip to do all that work . Can convert BCD to Binary and Binary to BCD. (DM74184/DM74185A BCD-to-Binary and Binary-to-BCD Converters) The only problem is Ive only found one place that still has them, mouser,newark, nor allied (or digikey) has them in stock.
Intrestingly, Ive found A/D that have BCD outputs or have 7segment display outputs integrated in the chip. I might go for those, if I can find one thats easy to use.
What Im trying to do is convert a voltage from a sensor to be read on a display (in my case-LM35, the data sheet shows how to do it, which is why I was going to use that chip)
Old 6th July 2006, 02:39 PM   (permalink)
Sorry guys. I screwed up exponentially!
Old 6th July 2006, 09:37 PM   (permalink)
[quote=What Im trying to do is convert a voltage from a sensor to be read on a display (in my case-LM35, the data sheet shows how to do it, which is why I was going to use that chip)[/QUOTE]
As it happens, when I used the ADC0804 I was using it to convert the output of an LM35 as well!!!
Brian
Old 7th July 2006, 05:09 AM   (permalink)
Ivefound a chip that will practically do it all! Its outputs are BCD and needs no control lines or clock ! All the chip needs is a couple caps and some resistors, along with the decoder chip for the 7segment.
I have another question, reguarding the LM35. I am trying to figure out what the voltage will be at a certain temperature. The data sheet says 10mV/C. Is this 10mV Per C or is it 10mV Divided by C to get V out? The A/D has a 200mV and 20V Capablity.
The A/D Converter is CA3162.
Old 7th July 2006, 02:26 PM   (permalink)
Degrees K, °K
Not made any more
FRIED is offline
Old 7th July 2006, 06:23 PM   (permalink)
It means that the voltage output from the LM35 will increase by 10mV for every one degree rise in temperature.
Brian
Old 7th July 2006, 08:22 PM   (permalink)
Brian
So then 200mV Scale wont be enough, since at room Temp (25C) I will be getting 0.25V. So then will a 2V Scale be enough?
Old 7th July 2006, 09:30 PM   (permalink)
Well it depends on your application. A 2V scale would give you enough room to measure up to 200 degrees C, although I think that far exceeds the capability of the LM35. If I remember from when I used it, it tops out at 50 Degrees C?
Brian
Old 7th July 2006, 09:37 PM   (permalink)
Brian
150C. Full range is from -55 to 150C.
Ive figured out how to calibrate it already, since it wll be reading in C, all I have to do is get a certain voltage (say .5V for 50C) and adjust the display so it will display 50. Of course I might leave the decimal out, but I'll leave the negative sign in.
