| Notices |
| | (permalink (permalink)) |
| At power up you have to follow next procedure to setup a certain counting mode and divider into the 4059. 1) With no power to the circuit set the 16 jam inputs J1 to J16 at a correct level depending on your divider. 1a) Let say you have a divider of 5070 and want to use the divide by 4 mode. 1b) Calculate the divider to set into the counter: 5070 / 4 = 1267 remainder 2 1c) Jumper setting: J1: remainder "1" = 0 remainder = 2 J2: remainder "2" = 1 J3: divider "1" * 10E3 = 1 thousands of divider = 1 J4: divider "2" * 10E3 = 0 J5: divider "1" * 10E0 = 1 units of divider = 7 J6: divider "2" * 10E0 = 1 J7: divider "4" * 10E0 = 1 J8: divider "8" * 10E0 = 1 J9: divider "1" * 10E1 = 0 tens of divider = 6 J10: divider "2" * 10E1 = 1 J11: divider "4" * 10E1 = 1 J12: divider "8" * 10E1 = 0 J13: divider "1" * 10E2 = 0 hundreds of divider = 2 J14: divider "2" * 10E2 = 1 J15: divider "4" * 10E2 = 0 J16: divider "8" * 10E2 = 0 2) Set all inputs Ka, Kb and Kc to a low level. Enable the "Master Preset Mode" 3) Apply power to the circuit 4) Apply at least three clock pulses on CP input 5) Set inputs Ka, Kb and Kc at a correct level according to the used "divide by" mode. For divide by 4 mode Ka low, Kb and Kc high That sequence is implemented by the gates in the "Logic.jpg" file. Set the 16 jumpers with no power to the circuit, then apply power. Wire i is low for at least 3 clock pulses from wire g. After that it has a high level setting the counter in de divide by 4 mode. IC4 makes 50Hz pulses from 24Vac after transformer. That is my counting frequency. During normal operation I need to count only when there is 24Vdc across D3 but since I need at least 3 pulses to setup the divider I made an OR gate with D4 and D5. Set up via D5, normal operation via D4. Need more? Ask... Last edited by mcs51mc; 5th July 2006 at 05:14 AM. | |
there is no schematic in the manual showing how to set this chip up at all. it says it needs to be set for "15 kHz - 20 kHz/1000" i've found the datasheet on this chip, but am still none the wiser as to how to set it up in a circuit. It looks as though you have already drawn this circuit out, but i'm not sure if you drew it with the specific settings i need. i'm not sure what Vdd or Vss (pins 24 and 12 respectively) stand for. My electronics expertise branches only from a "basic electronics" class in high school (1993-1994) I can read a schematic- for the most part anyway i understand what the circuit is supposed to do, but i don't know how to set up this chip. I looked at the jpg on your response and have a good idea about how to assemble it, but i'm not 100% sure about it. which jumpers should i close? Would you mind helping me with this? * i'm using a 12-15 Volt supply. * the frequency going in will be 15 - 20kHz * The output frequency needs to be 15 - 20Hz (Divide by 1000) * i already have the CD4059a chip Thank you for your time | ||
| 1) With no power to the circuit set the 16 jam inputs J1 to J16 at a correct level depending on your divider. 1a) Let say you have a divider of 1000 and want to use the divide by 4 mode. 1b) Calculate the divider to set into the counter: 1000 / 4 = 250 remainder 0 1c) Jumper setting: J1: remainder "1" = 0 remainder = 0 J2: remainder "2" = 0 J3: divider "1" * 10E3 = 0 thousands of divider = 0 J4: divider "2" * 10E3 = 0 J5: divider "1" * 10E0 = 0 units of divider = 0 J6: divider "2" * 10E0 = 0 J7: divider "4" * 10E0 = 0 J8: divider "8" * 10E0 = 0 J9: divider "1" * 10E1 = 1 tens of divider = 5 J10: divider "2" * 10E1 = 0 J11: divider "4" * 10E1 = 1 J12: divider "8" * 10E1 = 0 J13: divider "1" * 10E2 = 0 hundreds of divider = 2 J14: divider "2" * 10E2 = 1 J15: divider "4" * 10E2 = 0 J16: divider "8" * 10E2 = 0 I think that should be ok. | |
Tie pin 24,10,13 and 14 to power. 15V tie pin 1 to clock 20Khz the output will come out on pin 23. 20Hz Tie all other pins to gnd. The input clock signal must swing lower than 4.5V and higher than 10.5V in order for the part to see it.") Are you- by chance- working on a hydrogen generator circuit? Just curious because the requirements you described are for the same circuit i'm working on and came to a screeching halt on. | ||
