Old 2nd July 2006, 03:10 AM   (permalink)
Default Light sensor turns sound off, I want it to turn on
I am building a project found in the "Electronics for Dummies" pg 315 titled "When There's light, you hear this noise".
I am building it on a bread board and the idea is that when light hits the sensor a sound is made and when there is no light there is no sound, I have the oposite happening and I dont know what component needs to be switched for the desired result to happen.
The components are:
  • IC LM555 Timer
  • 2N3906 PNP transistor
  • 100k potentiometer
  • resistors and capasitors (1 capacitor is polarised)
  • and a speaker.
I am not sure what more information I should give to make it easier for someone to give advise.
Thanks in advance
Justin
mettam is offline
Old 2nd July 2006, 03:16 AM   (permalink)
I don't see any phototransistor or LDR (light dependent resistor) listed ? If you have one, where is it connected?
Russlk is offline
Old 2nd July 2006, 05:13 AM   (permalink)
Sorry I left out the Photoresistor.
So the components are:
* IC LM555 Timer
* 2N3906 PNP transistor
* 100k potentiometer
* Photoresistor
* resistors and capasitors (1 capacitor is polarised)
* and a speaker.
The Photoresistor is connected between a 100k potentiometer and the ground (to the neg of the battery, I asume it's the same as the ground).
One lead of the transistor (2N3906 PNP) is connected between the resistor and the Photoresistor the other is connected to the +V and the 3rd lead of the transistor is connected to the 4th Pin of the 555 IC as well as a 3.9Kohm resistor.
Can you give me an idea of how a curcuit can be described in words and I will do my best to decipher my schematic to you. Or I can send you a scan of the schematic.
mettam is offline
Old 2nd July 2006, 11:24 AM   (permalink)
Attached is a general circuit for what you are doing. I used an LED to signify the output... it could be sound, etc. As shown, the LED would glow in the presence of light. Reversing R1 and the photoresistor would give the opposite result.
AllVol is offline
Old 2nd July 2006, 11:43 AM   (permalink)
I have that book, i don't rate it, iv'e never tried that circuit, iv'e looked it up in the book, and what you need to do is put the photoresistor where the potentiometer is and vice versa, if you wish to learn more about electronics i suggest you get:
ISBN: 0-7195-7205-3
Success In Electroncs 2ND Edition by Tom Duncan, it is really good, lots of information about the operation of components, it's a few years old though, but still very good.
if you need anything more then just ask.
hope this helps.
ZIGGY_DAN is offline
Old 2nd July 2006, 02:46 PM   (permalink)
AllVol, you've got it backwards. Your circuit will turn the transistor off in the presence of light.
Ron
Roff is offline
Old 2nd July 2006, 06:05 PM   (permalink)
If it's (notice, not its) not one thing, it's a mother.
AllVol
AllVol is offline
Old 2nd July 2006, 09:54 PM   (permalink)
AllVol
I've been wondering if anyone understood my stupid signature. I think you do.
Ron
Roff is offline
Old 3rd July 2006, 04:34 PM   (permalink)
do this way. Use LDR and use LM324 comparator. Connect output of LM324 to the reset pin of 555. See
http://booksbybibin.14.forumer.com/viewtopic.php?t=37
http://booksbybibin.14.forumer.com/viewtopic.php?t=80
Bibin John
www.bibinjohn.tk
bibinjohn is offline
Old 3rd July 2006, 04:51 PM   (permalink)
reverse the position of the photoresistor and potentiometer..
jemilsan is offline
Old 3rd July 2006, 10:40 PM   (permalink)
Yes reversing the R1 and PhotoResistor did the trick. Now I just have to understand why.
Thanks for all your help.
Justin.
mettam is offline
Old 4th July 2006, 10:11 AM   (permalink)
The potentiometer and the photoresistor are acting as a potential divider, the voltage between them is dictated by the ratio of there resistances, since the resistance of the photoresistor is changing with light intensity, the potential diferance across the photoresistor is changing, with the photoresistor connected to the negative rail the voltage will go lower as the resistance of the photoresistor falls, with the photoresistor and potentiometer reversed the voltage across the divider will rise as the resistance of the photoresistor falls.
potential dividers are very common, and have a wide use of applications.
potential diferance means voltage.
hope this helps
Old 4th July 2006, 11:05 AM   (permalink)
The formula for a voltage divider is: Vout = R2/R1+R2 * Vin
All those who believe in psycho kinesis, raise my hand.
AllVol is offline
Old 4th July 2006, 02:46 PM   (permalink)
At the risk of sounding anal, the equation needs parentheses:
Vout=Vin*R2/(R1+R2)
Ron
Roff is offline
Old 4th July 2006, 05:09 PM   (permalink)
You did. rofl
AllVol is offline
