| Why do manufacturers recommend against charging NiMH batteries in parallel? | |
| I believe it is because of cells becoming unbalanced or varying cell capacities...whatever, I do it. If I ever find there is a problem, I will just build my machine to jump between the two batteries if one gets too low. | |
| Thanks for the quick reply. I thought that it might have had something to do with the unbalanced cells hoarding all the charge current. I was thinking that you could mitigate that problem with some creatively placed resistors or something. Thanks again. | |
| I just drain my cells regularily to almost minimum and then charge them up (I should probably charge them to nominal or just under nominal capacity so that no under-capacity cells get stressed. Battery discharge is a non-linear thing so you can't use external components to try and correct for it. Just take good care of your cells. | |
| For many years, my "beach amp" had its two series strings of 6 AA Ni-Cads connected in parallel without any problems. I used a National Semi stereo amp IC (discontinued now) bridged for each channel and got about 6W per channel into 4 ohm speakers all day long. After being on trickle-charge for about 20 years, every single cell ended its life shorted. The rechargable electric screwdriver I inherited must have been charging for at least 25 years and still works fine. It doesn't have paralleled battery cells.
| audioguru, are you saying that from your experience, it would be alright to charge in parallel? | |
| Since I had two strings of 6 battery cells, and the strings were in parallel not the individual cells, then they probably averaged to be the same. Both strings had weak cells and strong cells.
