Old 20th June 2006, 09:20 PM   (permalink)
Default Same source OP-AMP summing/adder circuit?
Say you have multiple circuits running off one battery (+12v).
Say the output of circuit #1 oscillates about +1.5v amplitude of 1v. (+1v - +2v)
I can't modify circuit #1. But I want to press a button, and while that button
is pressed down, offset the output of circuit #1 by +1.5v. (+2.5v - +3.5v)
Can this be done using the one battery used for all circuits?
Thanks,
Rey
elRey is offline
Old 20th June 2006, 09:34 PM   (permalink)
I'm sorry for my bad english but i'm Italian....
you can adjust the offset by plugging the voltage offset to the offset pin of an Operational Amplifier with gain=1
or you can build an Adder with an Operational Amplifier..
you can plug the inverting input with a resistor=1K to the ground, the out pin to this pin (feedback resistor) with a resistor = 1K and at the non inverting input you can plug your signal by a 330ohm resistor and the offset signal with an other 330ohm resistor (both resistor have a pin plugged to the same pin of the IC)
Ulisse is offline
Old 21st June 2006, 12:58 AM   (permalink)
This is how I would do it:
Russlk is offline
