+ Reply to Thread
Results 1 to 5 of 5
Thread: High Voltage Indicator??
  1. #1
    ZIGGY_DAN Newbie
    Join Date
    May 2006
    Location
    England
    Posts
    102
    Default High Voltage Indicator??
    I need a circuit to tell me when my capacitors are charged to around 200V or 400V, am i correct in thinking i can use a potential divider with high value resistors and a neon bulb, the resistor values chosen to give a voltage of 70-95V(i think this is the strike voltage for most neon bulbs)
    what kind of current do neons pull?, i wanted to use high value resistors to keep the current flow from the capacitors to a minimum.
    are there any other possible indicators other than neons, perhaps LED's??
    Thanks.
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,797
    Neons are very low current, as you say select the potential divider so it lights the neon when you wish - bear in mind that the neon WILL load the top resisor more and the voltage across the neon will fall, but it should still be OK, as the running voltage is lower than the strike voltage.
    You will probably have to experiment to find which values work the best!.
  3. #3
    ZIGGY_DAN Newbie
    Join Date
    May 2006
    Location
    England
    Posts
    102
    Thanks for the reply Nigel
    I will source a few neons and experiment a little.
    Are there any other options???
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,797
    Quote Originally Posted by ZIGGY_DAN
    Using a potential divider feeding a comparator?, plenty of options - but a neon is probably the simpliest one? (and is usually used in camera flash guns!).
  5. #5
    ZIGGY_DAN Newbie
    Join Date
    May 2006
    Location
    England
    Posts
    102
    Quote Originally Posted by Nigel Goodwin
    What a coincidence, this is what i am using my capacitors for and this why i need to know when they are charged, i think i will go for a neon.
    Thanks Nilgel
+ Reply to Thread
Tags for this Thread
