| I'd like to have two seperate potentials relative to ground using a 12.6V CT transformer. One will be used for 5V with a 7805 and the other 12V using a 7812. The ground is common to both circuits. I've never seen a center tapped transformer used in this manner, but in the simulator everything appears to work correctly without issues. The center-tapped lead won't require a diode because it obtains recitifcation through the outer winding legs going to ground. Will this work in reality or am I missing something? ![]() | |
| It's no different to a normal bridge rectifier giving a spilt supply, which is all you need to use - you've just drawn it differently! | |
[edit] Also, aren't the split rails normally the same potential? This is what I think of split bridged, but I don't think it's the same as the circuit above... ![]() Last edited by agent420; 14th June 2006 at 03:37 PM. | ||
| I think what Nigel is saying is that you have just redefined the reference node (GND). Draw the schematic without a GND first. You can then put GND on any node. The voltage difference between any two nodes will remain the same. | |
| I see. Thank you both for the insight. | |
Generally you measure with reference to ground or zero volts, but not always, and it's only a convention - nothing else. | ||
It's always interesting figuring out on your own a law or circuit approach. Often I have a much better understanding of it that way compared to simply reciting it from a textbook. [edit] Just thought of it, this situation is just like the 7V trick some pc mod people use to obtain a lower fan voltage from referencing between the 5V and 12V rails. Last edited by agent420; 14th June 2006 at 06:47 PM. | ||
| One guy I worked with used to draw schematics like that alot. It would drive you crazy trying to work it out sometimes. For him it was natural and made sense, but I was used to "seeing" it drawn like the second diagram. The trick was, as Nigel pointed out, finding the node that measurements were relative to. What complicated it ( for me anyways ) was that this coworker drew the AC buss as a parallel lines across the page, with branches coming off either vertically up or down with the diodes in all sorts of odd directions feeding the various secondary ciruits. | |
| For 'old' people, the early transistor circuits were usually +ve ground, and drawn with the negative rail at the top - basically because the only transistors were PNP. But I always found it hard to look at them!. | |
But OC71's were fine transistors, general purpose PNP audio, bit small for an output transistor though? - later on the OC72 became available, and was capable of more power. | ||
| I liked the powerful (for small transistors) complementary germanium AC127 and AC128 transistors. They were in a glass case, surrounded with thermal grease and had an overall small metal case. I guess in those days they didn't know how to bond the chip to the metal case then seal it.
