Old 13th June 2006, 07:11 PM   (permalink)
Default capacitors
Hi guys, first time poster here. I have an electric cement mixer which has decided to do no more mixing. It seems dead although checking contacts with a screwdriver, the neon light lights up, so electricity is getting around. Opening it up there is really nothing inside. A motor, a switch and a capacitor. The switch contacts seem clean. I was wondering if it could be the capacitor. Would that be likely ( do they blow often)? and if so do my symptoms sound like a capacitor has expired?
Thanks for all help forth coming.
howie209 is offline
Old 13th June 2006, 08:13 PM   (permalink)
If it's just a cement mixer and is that simple, it's not the capacitor probably. THe capacitor is just there to absorb voltage spikes and smooth voltage ripples from the motor as well as react to quick changes in power demand when the battery can't react fast enough.
Is the capacitor in parallel with the motor? If it is, that is what the capacitor is for and a failed capacitor would not cut current off from the motor and stop everything from running. If the capacitor blew...you wouldn know, hehe. Is it swollen? Even if it is, it wouldn't stop current from getting to the motor.
It's probably a burnt motor winding or something. (How big is this system anyways?)
dknguyen is offline
Old 13th June 2006, 08:51 PM   (permalink)
I agree with the motor being at fault. What kind of motor is it ?
bioborg is offline
Old 13th June 2006, 08:55 PM   (permalink)
I've never heard of a battery-powered cement mixer. Do they exist?
If the motor is AC-powered, the capacitor is what allows the motor to start. If it fails, guess what?
Do a Google search on "capacitor start motor".
Ron
Roff is offline
Old 13th June 2006, 09:02 PM   (permalink)
Originally Posted by Ron H
I've never heard of a battery-powered cement mixer. Do they exist?.
Get with the times! Haven't you ever heard of the saying "Mix cement in the comfort of your very own car?"\
Anyways, you are saying that some motors require so much starting current that the battery cannot provide enough? Not even enough for the motor to very slowly start? And that a capacitor has to be charged up to supply this current before the motor will start?
dknguyen is offline
Old 13th June 2006, 09:21 PM   (permalink)
Dknguyen, how is it that you joke (presumably) about battery-powered cement mixers, then proceed to ask questions about DC motors? Not all motors run on batteries (believe it or not). I repeat - Google "capacitor start motor".
Ron
Roff is offline
Old 13th June 2006, 09:23 PM   (permalink)
Usually when the start capacitor on a AC motor (batteries are DC), it's pretty obvious. They are also pretty cheap (under $20). Motors, one with enough horsepower to mix cement (mixed 11 X 80 lb bags by hand last week), I'm guessing $200- $300....
Anyway, if the start capacitor looks damaged... Swollen, top popped off, terminal missing, leaking fluids... might be a cheap repair.
Now, the motor... Well, if not overworked, its most likely fine. Don't know how old, or how much work its seen. If you use it professionally, 8-10 hours a day, 5-7 days a week, and only service it when there is trouble... yeah, maybe.
HarveyH42 is online now
Old 13th June 2006, 09:27 PM   (permalink)
I dunno, when I read that, I pictured a cheesy salesman saying that on TV and I just had to get it out. I also guess it never occured to me that the cement mixer might not be using a battery. A whole bunch of things make sense now. (When I thought that the capacitor might be there to assist the battery in fast current changes in current demand, I was thinking that running something as large as a cement mixer on a battery was a bit strange. Never occured to me that it might be plugged in a wall. WHen I think cement mixer I think a cement truck which moves around rather than being plugged into a wall.)
Case in point, yeah, makes more sense now when you say the capacitor is a starting capacitor considering something as large as a cement mixer probably would be plugged into the generator or something rather than a battery. I see your train of thought now.
PS. I googled an article about capacitor start motors and it makes a lot of sense now. Ive seen starting capacitors advertised but always thought that meant they were used to absorb the voltage and current spikes of a motor starting up, rather than providing a delay that is absolutely necessary to the motor starting.
dknguyen is offline
Old 13th June 2006, 10:01 PM   (permalink)
thanks for replies guys. The info is great. The cement mixer is mains electricity. I am in Scotland UK so its 240volts. There is no battery. The mains runs into the off/on switch from there onto capacitor and the to the motor. Is it possible to post u guys pics of my Scottish 'Mickey Mouse' mixer to let you see it. It would let you see the components.It was actually a great we mixer when it was going.Isposting pics possible? Thanks from Howie
howie209 is offline
Old 13th June 2006, 10:13 PM   (permalink)
On the posting screen, look a bit below to find the button "Manage Attachments" to post a picture
dknguyen is offline
Old 13th June 2006, 10:32 PM   (permalink)
Cheers dknguyen I shall post some pics tomorrow as it 10.30 at night in UK here at the moment. Thanks again. Howie
howie209 is offline
Old 14th June 2006, 06:01 PM   (permalink)
All your guys debate about my mixers fault is very educational for me. I have learned a lot just since yeaterday. Your knowledge has fascinated me and I thank you for that.Ok ive tried to upload pics of my mixer (not sure if ive done the right thing but will try again if they have no appeared). I appreciate that u cant sort a problem with pics alone. You can see the switch, motor and the capacitor on its side. Do you guys think it may be the capacitor after all now you know its mains powered?
Thanks from Howie in Scotland
howie209 is offline
Old 14th June 2006, 07:08 PM   (permalink)
It could be the capacitor, there are essentially two types - start capacitors (which are only used to start the motor spinning), and run capacitors (which are used all the time, and provide the required phase shift to make it run).
I would imagine your's is probably a run capacitor?, they seem more common.
Do you have the facility to check a capacitor?.
Nigel Goodwin is online now
Old 14th June 2006, 08:28 PM   (permalink)
Thanks Nigel. I would not know how to check capacitor unfortunately. Would a close up pic of the capacitor and the writing on it identify it as either a 'run' or a 'start'. If it was start capacitor would it be most likely that the capacitor is where the fault lies as motor does not start at all?
Thanks again Howie
howie209 is offline
