| Hello! I have Panasonic TV about 1 year old. It was working great til a few weeks ago, now it shows stripes/lines at the top of the screen that used to get better after tv was getting warm. Now I got more stripes/lines at the top of the screen and they don't dissapear even when tv gets warm. I removed the tv rear cover and found only 2 knobs for Focus and Screen and they won't solve the problem. I tried to adjust Var Resistor and again nothing. What can I do? What should I check for? Please help. Thanks, Russell www.tvnorthshore.com | |
| If it is only a year old call distributor you got it from then Panasonic and ask them what the HECK goes they should cover the product. It's only one year old. | |
From your vague description it 'may' be frame flyback lines you can see?, or even teletext lines? - but that would depend on where you are?. | ||
| it is the horizontal coil that you can adjust or your bright and contrast are not right they are det too high. | |
| Sounds like maybe the vertical sweep is not linear. Combine that with the "got better after it warmed up" and it sounds like either the DC for the vertical chip is saging from a bad electrolytic, or the vertical IC feedback electrolytic is bad. Possibly just bad solder joints around the vertical IC, but sounds more like a bad capacitor. The DC power for the vertical section could come from the LOPT, so the cap would likely be near that, not the vertical IC. This produces a vertical sweep ramp signal that is curved, instead of flat, stretching out the picture at the top. | |
