| Hello I have made a simple circuit with Atmega16 that writes only a word on LCD. when I connect all parts, the LCD only shows full boxes in the second line and the first line is empty. the LCD shows this even when the micro is off !!! The program is correct. the connections is correct too. I used another LCD and micro but they did the same. I dont know where is the problem?! please help me about this .... | |
| If the contrast is turned up too high, and the LCD isn't initialised at all, then you get the single line of blocks on the display - this is normal, and shows the LCD is worked to some extent at least. As it doesn't work how do you know the program and connections are correct?, one (or both) of then are obviously NOT OK. | |
| because the program is simple, in BASCOM I wrote : $regfile = "M16def.dat" $crystal = 8000000 Config Lcdpin = Pin , Db4 = Pinc.4 , Db5 = Pinc.5 , Db6 = Pinc.6 , Db7 = Pinc.7 _ , E = Pinc.3 , Rs = Pinc.2 Config Lcd = 16 * 2 Lcd "HELLO" and the connections are this way : pins : 1,3,5 -> ground 2 -> VCC 6 -> Pinc.3 etc ... I saw this configuration in some mannuals, but it does not work. If the problem was about the contrast, then only 5 characters must be filled , or all 32 charsets, but only 16 characters of second line become black boxes | |
If it doesn't work then something is wrong, either it's connected wrong, or the program is wrong (or both) - if they are both correct then it will work!. | ||
| ok! it may be from program or connections. but which and where? | |
I can point you to my tutorials, which give both a tested working layout, and tested working code - but it's in assembler. | ||
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." Last edited by akg; 31st May 2006 at 08:05 AM. | ||
| this is for LCD configuration (in BASIC language, with BASCOM ) : Config Lcdpin = Pin , Db4 = Pinc.4 , Db5 = Pinc.5 , Db6 = Pinc.6 , Db7 = Pinc.7 _ , E = Pinc.3 , Rs = Pinc.2 Config Lcd = 16 * 2 and the connections are this way : pins : 1,3,5 -> ground 2 -> VCC 6 -> Pinc.3 etc ... | |
| Sorry?, I fail to see your point?. Does that work?, if not why should you think it's correct?, and is your hardware correct?. | |
| ..in ur postes we don't see any lcd initialisation code ..... or is that there is nothing like it?
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." | |
| It worked I only changed the port C to port B. it worked | |
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." | ||
| The micro had no other functions.only handling LCD.It doesnt work with portC. I dont know why ? I didnt used any capacitor or resistor. I connected all grounds and VCCs and... directly. maybe it should be used some... It is a strange problem | |
A reasonable knowledge of assembler would probably have enabled you to sort this in the first place?. | ||
| we've used the atmel 89c51 controller..n the same lcd.the only output is the black bolcks with the back lights..we've used the assebly language prog.. the program, the connections work well in the protieus.. the testibg software.... but the result is hard to see on the LCD... we are unabe to trace the problem since a month ...require HELP!!!! | |
