| I've attached a web page with specs on a RGB LED. I would like to know if there is a simple way to get the brightness of each color to appear of similar magnatude. In my tests with (not optimal for sure) 1200mcd RED = 220 ohm 3700mcd GREEN = 220 ohm 700mcd BLUE = 100 ohm The Blue is the dimmest, the Red is bright, and Green very bright. Trial and error work to some degree but not very accurate, is there a math formula for mcd, VCC, color & current? http://www.superbrightleds.com/TriColor%20LED.htm
__________________ Bill Home of the Firefly PIC Tutor Inchworm ICD2 http://www.blueroomelectronics.com | |
| Each tri-colour LED is different. Each colour of LED in a tri-colour LED has a different voltage drop which causes a different current in the current-limiting resistor. Your eyes are most sensistive to yellowish-green, less sensitive to red and have very poor sensitivity to blue. The mcd spec's don't account for the response of your eyes. So there are too many variables for a formula that works.
| There's also the problem of deciding what 'white' is, it's not as simple as it sounds!. | |
there are formula that help you mix led output based on the CIE chart, but it's a whole lot of math and you have to rely on spectral emissions data from the manuf, which may or may not be accurate for the exact LED you have. depending on your application, you could use PWM to set the levels of the led, reflect it off something white, and adjust the levels until you get a satisfactory color. if you want a good bright "cool" white, you'll want two blue emitters for every red + green pair. if you want a good bright "warm / neutral" white, you'll want two green emitters for every red + blue pair ... LEDs of these type normally come in the 10mm (round) package, the piranha (superflux) package and the barracuda (luxeon) package. if you have access to a technical library or a university nearby, these publications might interest you: CIE 013.3-1995 Method of measuring and specifying colour rendering properties of light sources CIE x013-1997 Proceedings of the CIE LED Symposium '97 on Standard Methods for Specifying and Measuring LED Characteristics CIE 127-1997 Measurement of LEDs CIE x022:2001 Proceedings of the 2nd CIE Expert Symposium on LED Measurement "Standard methods for specifying and measuring LED and LED cluster characteristics" CIE 167:2005 Recommended practice for tabulating spectral data for use in colour
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | ||
