| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | is it possible to use elctrto magnets to compact snd i mean with crushing force and keeping it compacted with ions or someone while away from the magnet is there a way to make it magnetic working off of several really big caps and coils maybe more stuff
__________________ im me on yim its robotgangsta logh into my board at http://s14.invisionfree.com/ElectroTech_Beginner/ |
| Experienced Member | no i mean by melting it together with metals then seperating into granular peices and i want to use very very high voltage to pull it maybe from 5 feet away
| Experienced Member | I read in the datasheet, a flux capacitor can be used to magnetize non-ferrous materials ... it's one of the alternative applications, aside from the primary purpose of course.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
| Experienced Member | Beyond the other obvious limitations everyone else has already mentioned, if you are trying to smelt some sand to extract metals from it...the ore itself will not be magnetic. In the same way that you cannot use a magnet to pull rust off your car just because the rust contains iron ions in it. The ore must undergo a chemical reaction to produce iron in order for it to be moved by magnetic fields. Ions aren't affected by magnetic fields. (Has anyone ever wondered how Magneto was able to suck the iron out of the prison guard's blood in X-Men 2? The iron in the blood had to be dissolved as ions...not solid iron). NOTE: now that I think about it, I am not so sure iron ions and iron-compounds are not magnetic...I have never seen proof of it either way all I know is just that I have never seen it happen. Is what I said right? Last edited by dknguyen : 23rd May 2006 at 05:49 AM. |
| Experienced Member | Quote:
I was just at the beach. An important screw got lost in the sand. I tried to find it with a neodymium magnet and ended up picking up a TON of fine magnetic iron powder in searching even a fairly small area. Pretty shiny actually, not rust-colored at all. I was surprised as well that it was in that state and not iron oxide in a corrosive environment, perhaps some chemical reaction reduced it back to iron?
| Experienced Member | Come over for a holiday to Piha, West Auckland, New Zealand. We have partial black sand beaches here which are full of iron sands. Very heavy, fine very iron rich sand which is used for the local melter in Waiuku, South Auckland. With a magnet, Bingo loaded with clean black iron particles. Probably a strip of beaches West of the greater Auckland area of ± 200 kms are loaded with it. Pity that you are limited to take max. of 20 Kilo's aboard a plane. Regards Raymond |
