| ok thanks for all inputs, yes Nigel it works and i think the best postion is when i get a sine wave with highest amplitude(i have triangle waves mostly and it becomes a sine wave with highest amplitude at a specific freq) my small piezo has a resonance freq at 29kHz(i wish i could get a FLAT resonance for it to 40kHz!? Nigel, what did you mean with parallel and serial resonance in transmitter and receiver? | |
So for the transmitter you adjust for MINIMUM signal at resonance, and for MAXIMUM signal on the receiver. | ||
| Nigel, you have showed a pic to measure the resonance freq, i want to know if it is possible using it to find out the bandwith of a transducer? i saw a data sheet about an ultrasonic transducer that is able to work with 10kHz of bandwith, is it possible to measure its bandwith with that circuit? i think the conical of an ultrasonic sensor is "the most important" part that makes the piezo to has a resonance at a specific freq(i mean if you cut part of conical the the freq range will be changed) am i right? if so then how that ultrasonic sensor is able to work at a flat freq of 10kHz?? here is the link: http://www.prowave.com.tw/english/pr...e/400wb160.htm Last edited by epilot; 1st July 2006 at 05:15 PM. | |
Presumably this is still about your audio over ultrasonic project?, 10KHz bandwidth from the transducer should just about give you a low quality voice channel!. | ||
yes this is about my experiment with ultrasonic and modulation, anyway i have no access to that kind of wideband ultrasonics but if there was a way to solve the problem with the receiver part and use SSB then 10kHz is ok. i have alot of peizo ceramics(resonance freq is near 28kHz) do you think it is possible changing their resonance freq usinf a conical? Last edited by epilot; 2nd July 2006 at 01:27 PM. | ||
| | (permalink) | |||
it is amusing.(i am a stubborn person lol) | ||
| The piezo vibrates at its cut freq. like any crystal. | |
| You can tune the output to one of the crystals harmonics but of course the amplitude will be lower. Build a Pi filter tuned to the harmonic you require. | |
