Old 21st April 2006, 10:47 PM   #1
Default Neg 18 volts from laptop battery
I need to convert a +18 volts coming from a laptop battery to -18 volts. Can someone please give me some ideas / direction?
creichard is offline
Old 22nd April 2006, 03:11 AM   #2
Why not turn the battery around?
Russlk is offline
Old 25th April 2006, 02:16 PM   #3
If you want to invert the voltage of the battery, you may need a switching (inverting) regulator. The output voltage can be greater than the input voltage (absolute values).
eng1 is offline
Old 28th April 2006, 09:56 PM   #4
LOL Russlk,
Seriously tho, that is the best solution
iso9001 is offline
Old 29th April 2006, 03:49 AM   #5
Do you want +18 to be plus and minus 18?
If you really want +18 to be -18, use the plus side of the battery as ground and the negative side as plus.. That is, flip the battery like Russlk said.
mramos1 is offline
Old 29th April 2006, 12:45 PM   #6
Most laptop batteries supply 14.8 V (or less). So a swithcing regulator seems necessary to me.
If the battery really supplies +18 V but you need both the positive and the negative voltage, a switching regulator would be necessary again.
eng1 is offline
Old 29th April 2006, 03:38 PM   #7
A laptop battery is not just a battery. I did an autopsy on one and they have an elaborate circuit board wired or sensed in parallel and series.
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline
Old 29th April 2006, 10:24 PM   #8
that circuitry is a battery supervisor circuit, providing some basic functions, to prevent your battery from doing a 3-mile island style meltdown
1) short circuit protection
2) prevent excessive rate of discharge
3) prevent excessive rate of charge
4) prevent over voltage charge
5) prevent deep cycle discharge
6) prevent excessive cell temperature
7) monitor and report individual cell health
8) record battery statistics, date of manuf. and unique serial number
9) provide "fuel-gauge" calculations; state of charge, discharge rate, run-time remaining at current discharge rate, charge-rate, charge-time remaining, etc.
7 to 9 are mostly features of newer "smart batteries"
justDIY is offline
Old 30th April 2006, 02:36 AM   #9
They said they had a +18 volt battery. What part in that says there is a 14.8V regulator? They want a -18VDC power source to something I assume. Flip the positive and negative lines
I just checked my Sony laptop and it is 16.9VDC out. I guess the 14.8 volt regulator in my Sony battery is not working tonight.
creichard: Are there only two wires from this laptop battery? Is it in the laptop when you are tring to get -18V out of it? Are you tring to tap +18V from the circuit board?
mramos1 is offline
Old 30th April 2006, 11:15 AM   #10
The regulator is not inside the battery or the laptop. It is a circuit you need to setp-up or invert a voltage. That's just one possibility ( if the battery is in the laptop while trying to get -18V )
eng1 is offline
Old 30th April 2006, 02:15 PM   #11
Lots of replies here to a badly defined problem.
The OP has not replied to any of this, so it is not clear if he has even seen any of the answers.
I think he needs to define what it is he is really trying to do before anyone can give a definitive answer to his question.
JimB is offline
Old 1st May 2006, 02:46 AM   #12
JimB: I agree, they said coming "from" a laptop battery and 18V led me to believe 2 wires.. But you are 100% correct.
mramos1 is offline
battery, laptop, neg, volts
