Old 19th April 2006, 04:19 AM   #1
Default Typical IR LED; what is the voltage drop & max current?
Seems I'm looking in the wrong place on Google for IR LED datasheets. I do recall they can be used at upto 100ma (50% duty cycle?) are they 1.2v drop? 1.7v?
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline
Old 19th April 2006, 09:21 AM   #2
Default Re: Typical IR LED; what is the voltage drop & max curre
You need to look for the specific one you have, try LD274 for one I happen to be using at the moment. I'm running it off 3V (2xAA) from a 16LF628, using an NPN driver with a 6.8 ohm series resistor.
It's normal to pulse tham around 1A, with a fairly low duty cycle.
Old 19th April 2006, 01:29 PM   #3
Thanks Nigel, your experience is helpful as always. Perhaps you could clarify the following spec in the datasheet. Since I'm using 5v does it mean the diode will drop 1.9v
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
Old 19th April 2006, 03:44 PM   #4
Looks like it to me!.
Old 20th April 2006, 12:51 PM   #5
The voltage across the LED will be 1.9V with a forward current of 1A. And note the 100 us pulse requirement, ie. the 1A must not be on for longer than 100 us.
With a current of 100 mA it will be 1.3V, note the 20 ms pulse.
Given the brief extract quoted, these appear to be typical figures. The maximums are 1.5 V and 2.5V respectively.
Len
ljcox is offline
current, drop, led, max, typical, voltage
