| I'm going to be using a LM2679 regulator for a switching power supply that outputs 5V as 5A, but the question I have is for the input for the regulator. If I use a transformer and bridge retifier as the DC input for the regulator, what does the transformer need to be rated at? Do I have the option to use any transformer as long as I have a minimum of 25VA of power? What about the bridge rectifier after the transformer, does the voltage/current rating need to match the transformer? | |
| Anybody? | |
| Looking for a bit of help here. | |
| The basic rule of thumb: get a transformer atleast twice the rectified/regulated output current. The diodes rating MUST exceed the transformer current ratings several times ( atleast 4), for better safety and reliability, although you can getaway with 1/2 ratings fro a bridge rectifier. | |
| For 25W of output power the transformer must be rated for 25VA plus more current to heat the filter capacitor and rectifiers. If you have a full-wave bridge rectifier then it will have a 1.5V or more voltage drop. The rectifier's loss is difficult to calculate due to the pulsing but is roughly 1.5V x 5A= 7.5W.
| I have a problem with LM2679 adj ,I used the software in national semiconductor and i connect the exact same quantities,but my circuit doesn't work,I just have around 0.6 of output current and 3 amperes in input! please help me,I really need it. | |
| A drawing or photo of your work would help us to help you. | |
It's not true, a rectifier only needs to be rated for half the current since it only conducts for half the time. Most rectifiers can also handle some pretty heavy surges and shouldn't be damaged charging the reservoir capacitor.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
