Old 6th April 2006, 08:01 AM   #1
Default 3.3v MAX232?
I am looking at a system where I need to lower Vdd from 5v to 3.3v. However the ST232 (same as a MAX232), but that's rated only for 5v. Even if the logic works the same since it's a capacitive charge pump obviously any change in Vdd will be reflected in its output level which could make its output levels unreadable by another receiver.
I don't want to use 2 regs. Is there a RS232 transceiver that runs on 3.3v? It would preferrably need to be a very low current device like the ST232.
Oznog is offline
Old 6th April 2006, 09:59 AM   #2
This might not be exactly what you're lookin' for but the open-drain outputs and pull-ups work great on anything (PC or laptop) I've connected to at data rates up to 115-kbaud... I've used VDD=5v and VDD=3.3v on the PIC side and the pull-up on the RS232 side can often be 5v on some laptops all the way up to 13v on some desktops...
Regards, Mike
3.3v MAX232?-rs232_2n7000_schematic_2.gif   3.3v MAX232?-rs232_parasitic_power__2_206.jpg
Mike, K8LH is offline
Old 6th April 2006, 02:56 PM   #3
Texas Inst has a few (11) 3.3v compatible rs232 drivers ... this link is for the cheapest one
http://focus.ti.com/docs/prod/folder...sn75c3221.html
Maxim (for whom the MAX232 was named?) has a bunch
http://para.maxim-ic.com/cache/en/results/5020.html
justDIY is offline
Old 6th April 2006, 03:17 PM   #4
Best/cheapest one I've found is the ST3232. $1.66 if you are willing to go SMD, otherwise $2.60 for DIP.
http://www.mouser.com/catalog/625/246.pdf
I use these all the time.
Mark Higgins
DirtyLude is offline
Old 6th April 2006, 05:46 PM   #5
The MAX3221 works just fine at the lower Vcc. It has one TX and one Rx. We pay $1.37 It probably has a brother with two Tx and Two Rx.
Papabravo is offline
Old 6th April 2006, 07:36 PM   #6
Where do you get that from? The ST3232 above has 2 TX and RX lines, but I've never actually needed 2, so it seems like a waste.
Mark Higgins
Old 6th April 2006, 08:43 PM   #7
You can get them at Arrow, Digikey, and Maxim.
Old 6th April 2006, 09:45 PM   #8
Nice. It's $1.25 from Digikey in TSSOP package.
Mark Higgins
Old 7th April 2006, 05:16 AM   #9
Thanks! I should be able to get a part that fits my needs then.
Oznog is offline
Old 7th April 2006, 01:59 PM   #10
Glad I was helpful.
33v, max232
