Old 3rd April 2006, 01:44 PM   (permalink)
Default Soldering iron, you're FIRED!
Well, lets face it, my soldering iron has significantly degraded in quality.
It is over 3 years old, and I have a problem. I think one of you guys were against sanding the circuit board before soldering it. I sanded it, because I wanted a fast way to remove the etch-resist after etching, so I used sandpaper.
But that didn't make my big problem now, because solder could always flow through properly.
But now, my problem is big. I tried replacing the tip, and grinding the old tip, and I get no success. I'll be lucky if I touch the solder and after 20 seconds of holding the tip on the solder, the solder melts. The solder melts faster after I grind the tip. I also notice that within 20 seconds after the tip is grinded, I have a blackish tip.
I can't remember if my iron is a 30 or 45W one, but I think I need to upgrade to a 45W.
I have a gut feeling an iron replacement is necessary.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 3rd April 2006, 01:58 PM   (permalink)
i'm sorry if this is too hard for you but i must say: "You are an idiote!".
as your soldering iron is/was 3 years old then this means it has good tips. and you never(i mean NEVER) grind them. hey have a wery good resistant shealding on the tip and when you grind that away then youd tip wont heat up, wont take solder and burn out wery fast (and may take your iron with him).
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 3rd April 2006, 02:49 PM   (permalink)
First off, I don't know exactly what etch resist you're using, but generally using a solvent is a much easier way to remove resist... For toner transfer, I use lacquer thinner. Sanding just seems like an easy way to weaken the traces more than necessary, not to mention it's a lot more labor-intensive than simply wiping the board a few times with a paper towel with some solvent on it.
I once tried grinding the tip of a soldering iron in my early electronics days, because it was a very cheap iron and I wanted to try and make a finer tip... turns out that for mine at least, the center was copper, and it the outside was a shell of some other metal, sort of like a jacketed bullet or something... anyway, soon after I ground away enough that the center was exposed, it started corroding really bad and within a few days of use the center part was eroded quite bad, leaving nothing but the thin metal shell on the outside.
moral of the story, as you learned: don't screw with your soldering iron tips.
if you really need a better soldering iron, buy a decent temperature-controlled station, there's no substitute... are you really planning to use a 45W non-temperature-controlled iron for normal soldering on PCB's?? the only time I use an iron that big is when I need to solder wire as heavy as a coathanger or something :lol:
EEgeek.net
evandude is offline
Old 3rd April 2006, 02:56 PM   (permalink)
You are doing something wrong, or it is a bad iron.
I have 2 weller irons that are 20-25 year old. Still the same tips, now I only use them 4-5 times a month, but still..
Do you tin and clean the tip when you are done with them? I recommend weller, as I can not seem to kill these two.
(I saw Nigel bought a new one and went to their website today).. hehehe.
You can never have too many soldering irons.
mramos1 is offline
Old 3rd April 2006, 03:07 PM   (permalink)
hyedenny
LOL
Old 3rd April 2006, 04:31 PM   (permalink)
Default Re: Soldering iron, you're FIRED!
My Iron is over 30 years old. Usually replace the tip once every year or so and I solder Every Day.
Solvent usually Works Good.
Steel Wool or an SOS Pad, Than RINCE Well in Warm water, is good.
But NEVER SAND IT.
Most Tips are Carbon Core with a Steel Plating. Removing that Steel and your tip is USELESS.
30 Watts is good. 45 Watts may be Too Much for you on smaller traces.
Unless your Really good at Soldering. And it Doesn't sound like it.
Now: Since your in Canada, So am I.
So if you want more good advice, Email or Phone me.
My Website gives my phone number.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 3rd April 2006, 04:55 PM   (permalink)
Don't you mean COPPER with a steel plating?.
Old 3rd April 2006, 07:02 PM   (permalink)
The Weller tips are nickel-plated if I recall correctly. I believe the core is iron. There may be a passivation layer of copper plating between the iron and nickle.
Oznog is offline
Old 3rd April 2006, 07:10 PM   (permalink)
Try the tip activator described here, it makes wonder with a old tip.
There are more tips on solder irons too
http://www.mbouk.co.uk/pdf/weller.pdf
TOK
Gorgon is offline
Old 3rd April 2006, 09:57 PM   (permalink)
Some are, but the ones I have for my OLD, "Ungar Soldering Station" Are Carbon Core.
And Yes, Some are Nickel Plated, Mine say there "Iron Clad".
Either way, Filing them is a NO NO.
chemelec is offline
Old 4th April 2006, 12:41 AM   (permalink)
I feel better knowing chemelec has an older soldering iron than I have. I left the post and said to myself... I just told them how old I was...
Nigel's (I think it was he) new iron has made me think I need a fathers day gift.
mramos1 is offline
Old 4th April 2006, 05:35 AM   (permalink)
then what about a 'coldheat' soldering iron.?
Gods own Country
Incredible !ndia
www.flickr.com/photos/_akg/
"Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime."
akg is offline
Old 4th April 2006, 08:06 AM   (permalink)
Useless piece of junk! - see the previous threads!.
Old 4th April 2006, 02:15 PM   (permalink)
I took it upon myself to purchase steel wool, and rub my entire soldering iron with it, and it seems to be working better now.
mstechca is offline
Old 4th April 2006, 03:35 PM   (permalink)
I too bought the cold heat. Returned it the next day. Junk for sure. Tip to wide, part of it broke off as well.
mramos1 is offline
