| Hi. I was wondering how similar the LM324 was to the 741. I have a breadboarded circuit made with 741 and 1458 chips and those work fine for it, but when I make it as a unit I intend to use some quad op-amps to save space and connecting up lots of power rails. I found that some of my 071 chips oscillated and I couldn't seem to control with any method (supply rail caps, small cap in feedback loops, resistors on output). So i'm specifically looking for a low bandwaidth quad op-amp, in this list: http://www.rapidelectronics.co.uk/rk...4443&XPAGENO=1 Noise is not an issue as its dealing with large voltages, and the absolute maximum frequency is 20khz (usually well below that, this is a low frequency muliple waveform oscillator). Thanks.
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| If you keep the output level low, the poor high frequency response of the 741 and M324 old opamps won't matter much.
| Looking at those graphs it would seem the LM324 is quite similar to the 741 (slightly slower even), certainly not on op-amp that will oscillate, so its probably a good alternative. No problems with using it as an alternative? functions used including low gain inverting amps, summing amps, schmitt trigger and ramp generators.
| That sounds bad... I see there is an LM324, and an LM324N, which is specifically labelled low power, but you say they both are? There isn't a quad 741 is there?
The negative feedback you apply to the circuit sorts the crossover distortion out!. | ||
The datasheet for the LM324 shows how to add a DC load to its output to bias one of its output transistors into operating in class-A for low distortion.
| Getting a bit of a mixed response :lol: I think i'll just use 1458s, unfortunately out of stock at the moment. Or 074s, if I could stop them oscillating somehow, whats the standard way? 0.1uF ceramic caps between +v and -v, or 2, one from +v to gnd,another from gnd to -v? Niether of those seemed to work on an 071 set up as a buffer.
| Hi Dr. Em, I have used thousands of Texas Instruments' TL07x opamps in circuits and they don't oscillate. Only the very 1st one I ever used oscillated that was feeding a shielded cable without a 100 ohm resistor in series with its output to the high capacitance to ground of the cable. Japan New Radio (JNR) copied the opamps and they all oscillated. Please post your oscillating circuit for us to see what is wrong with it.
| Ok, i've changed all the op-amps for 071/072 chips and they seem to be working. It was just the output buffer that was oscillating, but there was some unshielded cable connected to that, so mabye thats why. Another had periodic oscillations on the waveform, but this was tamed with a 10pF in the feedback. So it looks like 074s will be ok, but i'll stick with 741 for the output buffer (the high slew rate of the 071 will probably cause some pops in the speaker on square waves anyhow)
