guys, i'm a 2nd year engineering student majoring in mechatronics and i found this forum while looking for ideas for my design project. basically we're supposed to build a machine that at a push of button will start launching 'seeds' to the left and right into designated patches on the track while travelling on an L-shaped track which has an overall length of about 5 meters. the machine has to stop at the end of the track. points will be deducted if our machine rolls off the track. all the different systems of the machine have been planned. push button > machine moves and launches seeds > cut power to motor and brakes are applied. my team members and i have opted to electronically switch from one stage to the other but i am now having problems as to how this can really be done. i am not very good at applying my electrical and electronic knowledge in real life yet so any suggestions are most welcome. thanks for your time. | |
| | #2 | |
okay my machine's operation is basically divided into a few stages, 1. push a button (START) 2. the vehicle travels along an L-shape track while launching 'seeds' left and right into pre-determined patches on the track. 3. because the machine can't roll off the track after its operation(pts deducted), power must be cut from the main motor 4. brakes are applied to completely bring the vehicle to a stand still(END) some extra info, my machine must weigh less than 15 kgs and not be more than 40 cm cube in volume. so basically i have to design a circuit to switch from one stage to the other. we do not want to do this mechanically since its pretty unreliable at our current level of skill. once again thx for your time. hope my explanation is clear enough | |
| | #4 | |
thx lots. not really familiar with micro controllers but will read it up in the micro controller section. another question, any ideas on how i should implement the brakes? i definitely need a braking mechanism. i was thinking of improvising from a car's disc brake. 1. fix a rigid disc to the axle of my vehicle 2. place a small dc motor on each side of the disc 3. connect each motor to a rack (horizontal gear) and attach rubber pads to the ends of the racks. 4. when power is supplied, the rubber pads on the racks should press against the disc, creating friction on the disc and slowing the vehicle down. can you guys picture it? any other ideas? | |
| | #6 |
You could use solenoids to apply pressure to the discs. What uni are you studying at? I'm currently a first year mechatronics student at the Uni of Wollongong, in New South Wales, Australia (an hour or so drive south of Sydney). | |
| | #7 |
solenoids? as in using an electromagnet? i'm studying at monash malaysia. mechatronics student 2nd year. | |
| | #8 |
asfor brakes you could just short the motors two wires (conenct both wiret to ground OR V+). the motor then is its own brake and you save a lot of money and time (use both to partey )
__________________ Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. | |
| | #9 |
short the motor? what will happen?
| | #10 | |
| | #11 |
motor is creating its own electricity and then sends it straight back to himself and then "bubu" it wont run that well anymore creating nice braking. (even better than "external2 brakes cause this "brake" can't get dirty or wet and slippery .
| | #12 |
okay ill try it. but can the motor be reused again? i mean like shorting it won't damage the motors original function will it? i am going to need to test the system numerous times.
| | #13 | |
| | #14 | |
| | #15 |
yes you can use the motor again cause it does nothing to the motor. (nothing signifficant). you can test it and use this brake for many-many years. (at least i have done so.
| mechatronics, project, suggestions, uni |
