| Does anyone have a calculator that includes diodes in the wiring diagram. All of the ones ive seen so far use resistors only. This is what i have in mind. 20 superflux amber leds 2v, 60ma -70 maeach. in 4 arrays of 5 leds. I dont know how to use a voltage regulator. THanks in advance.
__________________ email: camunteanu@gmail.com http://i32.photobucket.com/albums/d2...tvsdayfogs.jpg | |
| You don't use a voltage regulator for LEDs. You limit the current with a resistor or a current regulator. Are your LEDs rated for such a high current? Most LEDs operate at only 20mA with 30mA as max.
| I have just got some diagrams. | |
| You can also use ordinary transistors to regulate the current for LEDs:
| thanks By the way, these are superflux. They have the square bases and they are made to burn hotter = more light. Im sure some of you have seen them, the sit a little above the circuit board (1mm) and they have 4 legs (2 identical) for the power leads. I found out 50ma is a safe operating voltage. THey are not super bright because they have a 70 degree viewing angle, therefore the light is very spread out vs the traditional 20 degree 5mm leds. Thanks for the help guys and audioguru for the diagrams. I think i will use transistors. I read an article of some sort of wiring diagram that use diodes (thats why i brough it up) kinda like veins. The diagram had a valve sorta shape. With current only being allowed in one direction. IT was neat, and they were called diodes... You guys know best. Thanks.
